trailer deck |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 85819 |
![]() ![]() ![]() ![]() ![]() Posted: 19 hours 60 minutes ago at 2:48pm |
we have a 16 ft utility trailer that is about 25 years old. The deck was getting bad an punched one hole thru one board last month. I bought 10 - 2 x 8 pressure treated and let them set outside under the awning for a month to somewhat dry out.
I took the old boards off and the BOTTOM of the boards looks half way decent. I had painted the TOP with used oil 3-4 times in the past 6 years... Thats when we bought it and the deck was VERY DRY - CRACKING.. I painted the NEW 2 x 8 on one face and both sides laying in the driveway. My plan was to install that side DOWN, then paint the TOP with the used oil after installed... Now im wondering if the BOTTOM should be painted ? Bottom of 20 year old boards looked pretty good.. Maybe the BOTTOM should be open so it can BREATH ? Wonder if i should just install now with the OILED side UP ? ..... anyone else notice the BOTTOM of their trailer boards compared to the TOP ??
Edited by steve(ill) - 19 hours 57 minutes ago at 2:51pm |
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24387 |
btms are always better since the sun don't get to them.... oil ALL 6 sides,x3 on the ends !, redo every 5 years
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3779 |
Same happened to my car trailer. My daughter was wanting to build raised bed gardens so they got repurposed. New deck on mine should last till I decide to replace the trailer
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 3987 |
Mine is steel, I just let the tractors oil the deck. Really wish they didn't though. Some more than others.
Codger ![]() Orange Level ![]() ![]() Joined: 23 Dec 2020 Location: Utopia Points: 2238 |
Haven't had time to redeck my skid steer trailer yet. Purchased the lumber and stripped the old. Loose layed the boards to haul a couple of tractors and such and one 2X10 is already bending along it's length. I'll "jack" it back straight this weekend as I bolt them down.
That's All Folks!
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 2913 |
Treated my 12' utility trailer with linseed oil because that's what I had. Probably needs another coat. Thanks
