Tractor "quiz" pg 4
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Tractor "quiz" pg 4
    Posted: 24 Apr 2017 at 11:02pm
Ok last page of the tractor quiz.
19.    In the WD-45 power created engine with 6.5 to 1 compression ratio:
          ( ) a. Only premium fuel may be used.
          ( ) b. Premium fuel performance is obtained on regular gasoline.
          ( ) c. Less horsepower is obtained on regular gasoline.
20.    Maximum floatation on tractor drive wheels is obtained by:
          ( ) a. Increased tire size.
          ( ) b. Using correct air pressure.
          ( ) c. Removing liquid ballast.
21.    The hand clutch on the CA tractor is a:
          ( ) a. Multiple plate wet type clutch.
          ( ) b. Single plate wet type clutch.
          ( ) c. Single plate dry type clutch.
22.    The use of pressure radiators on model B, CA and WD-45 tractors:
          ( ) a. Raises the normal operating temperatures.
          ( ) b. makes engines run cooler.
          ( ) c. Eliminates the need of a water pump.
23.    The term "power-crater" used in connection with the WD-45 engine refers to.
          ( ) a. The shape of the cylinder head.
          ( ) b. The shape of the valves.
          ( ) c. The shape of the piston head.
24.    The automatic traction booster on the WD-45 and CA tractors:
          ( ) a. Positions an implement for working depth.
          ( ) b. Gives more traction with pull type implements.
          ( ) c. Uses some of the weight of mounted implements for traction.
Ok guys last page of this quiz next week ill have one of he implements quiz.
Enjoy.
Edited by Mikez - 27 Apr 2017 at 9:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2017 at 9:35pm
Nobody wants to play anymore
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2017 at 5:55am
19 = b
20 = b
21 = c
22 = a
23 = c
24 = c
There, I've hidden my answers
Edited by Lonn - 28 Apr 2017 at 6:05am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2017 at 5:58am
We want the youngsters to give some answers.
It's no fun if those of us "Golden Oldies" give the answers right away....
I'll give em a couple more days to see what happens.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2017 at 6:00am
SURE!!  Lonn types faster than me...
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2017 at 6:06am
I'm sure not, I just get up earlier Big smile
Wink
I am a Russian Bot
JarrodACFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2017 at 12:16pm
Here's my best guess:
19: B
20: B
21: C
22: A
23: C
24: C
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2017 at 9:38pm
Here you go.
19. B.
20. B.
21. C.
22. A.
23. C.
24. C.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2017 at 9:42pm
The guy that worked for my grandfather took this test in January 29/1957.
And got a 92% on it.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2017 at 7:55am
I got them right
Wink
I am a Russian Bot
