Tractor cab heater
iowallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iowallis Quote  Post ReplyReply Direct Link To This Post Topic: Tractor cab heater
    Posted: 23 Sep 2026 at 8:22am
I have a MF 1140 compact tractor with a cab and a loader.
The factory heater quit working and the cab manufacture, Curtis, has not responded to any inquires I have about parts, so replacing the whole heater unit.
Question- Does it make any difference which hose, inlet or outlet, that the water shut off valve is located in? Currently on the inlet side, but with the new heater it will be much more convenient to access it on the outlet side. Would like to keep the valve to shut off the flow as it already gets toasty in the cab during the summer.
DanWi View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2026 at 5:22pm
I would think shutting the outlet off would allow just a little more heat make its way up to the heater unit.
Les Kerf View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2026 at 8:11pm
With no flow it won't allow a huge amount of heat through, I would try the more convenient method and see if it works well enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2026 at 6:56pm
1/4 turn valves on both where connected to block
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2026 at 7:13pm
Either one will stop flow - the residual heat travel should be nil and either way if no flow enters core
Post Options Post Options   Thanks (0) Thanks(0)   Quote iowallis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2026 at 7:35am
Took a closer look at the new heater and the pipes are not labeled as "inlet" or 'outlet", so probably doesn't' make a difference which hose gets attached to which pipe. Looks like I may have enough slack in the heater hoses from the engine to cross the hoses over each other and make the original "inlet' hose closer to be more accessible to shut off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2026 at 2:55pm
Automotive use sometimes had different size hoses , larger on inlet , smaller diameter on outlet -
Post Options Post Options   Thanks (0) Thanks(0)   Quote iowallis Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 29 minutes ago at 7:35pm
They are the same size.
I ended up replacing the heater hoses, figured it was a good time to do it since I had the system 1/2 drained.
Went to the one of the chain auto parts store (is there anything else in this day and age?) and the older gentleman at the counter asked if he could help me with anything as I walked into the store. As I approached the counter I said I need 7 feet of 5/8th inch heater hose. He said "Okay, what is the year, make, and model?" I said "does it make a difference?" He said "I can't look anything up without that information". I said "it's for an old tractor, can't you do a generic parts search of 5/8th inch heater hose on your website like I did about 10 minutes ago to make sure you have it in stock?" He did some typing,  mumbled something, and went and got what I asked for. Jeesh!!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 48 minutes ago at 9:16pm
Yeah, I get that same reaction too... so I'll give them the year, make, and model, and when they can't find Kaiser, or Studebaker, or Clark, or Allis-Chalmers, most will give up.
"Hey, you got a front knuckle bearing for a 1933 Marmon-Herrington?"Wink
This page was generated in 0.046 seconds.
