WD conversion
twotall911 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twotall911 Quote  Post ReplyReply Direct Link To This Post Topic: WD conversion
    Posted: 18 Mar 2010 at 6:42pm
on the six volt to twelve volt conversion alternator the 10S1 what should i use one wire or two ive been told this is too big for the space to be put in any ideas thanks
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2010 at 10:33pm
you want to use the 3 wire version, the one wire does not work at low RPMs. should fit fine just need to use a bolt spacer with the stock bracket or there are a few guys who make custom brackets for an alternator conversion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote twotall911 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2010 at 2:40am
thanks for the info
