Aluminum Allcrop?
Kansasrustbuzzard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansasrustbuzzard Quote  Post ReplyReply Direct Link To This Post Topic: Aluminum Allcrop?
    Posted: 06 Jul 2014 at 10:55pm
I was looking in a guy's junk pile for some parts for my combine and he had a very poor Allcrop 60 that had most of the paint worn off. I was kind of shocked to see it was Aluminum. I have seen several dozon of these units and most were galvanized under the orange so is this one special? It would be pretty tough to restore, lots of stress cracks plus its been parted pretty well. Just curious, thanks.
Cen IA John View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cen IA John Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2014 at 1:35am
I have seen a lot of AC60s but never one with aluminum. What parts are aluminum? Get some pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2014 at 6:42am
Galvanized sheet metal, yes.....aluminum anything else, no.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2014 at 9:12am
Get a magnet and check it.  MACK
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2014 at 10:24am
Brother has seen another one that that had aluminum sheet metal. It was sold in a big line of junk to a scrap man at an auction. He didn't buy it because it was quite expensive to buy all the scrap with it. So brother thought he would come back in a couple days and buy it from the scrapper. I told him he needed to go right back that day and make the deal but he thought it would take weeks to cut up all the scrap. 2 or 3 days later I went with him to the farm site and nearly everything was gone. It was too bad. I'm sure I read somewhere that there was a shortage of steel at one point and AC went to aluminum for a short spell. I think they also made some B or C fenders made with either aluminum or something different too for a short period. Oliver did the same thing at the same time and built a few tractors with aluminum sheet metal. I've seen one of those Olivers at a show or auction years ago.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cen IA John Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2014 at 11:28am
So we are talking like roof flashing for the sheet metal area. What years might that be? All of the ones that are around here are galv steel/tin. We had 2 on this farm and both were steel. Many AC60/66 are in fence rows and parked in corners all around here, still haven't seen aluminum.
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2014 at 12:24pm
During the end of WWII galvanized sheet metal was in short supply. A-C was wanting to get stuff produced and out the door, for some reason they had a large supply of aluminum so they started using that on the All-Crops as well as other machines. Of course the aluminum did not hold up as well as the sheet metal did. I had heard farmers complain that they were always patching holes all over the machines. I have seen a couple that were in running condition and have seen a few and heard of a lot that had gone to scrap due to reliability issues.
I own one that the left half is mostly aluminum. I also own a outer divider for a mounted picker that is made up of aluminum as well although it is badly damaged it is still an interesting piece.
Jim
mrlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrlogli Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2014 at 1:02pm
There was a lot of aluminum sheet metal left over after the war from aircraft production and it was cheaper than steel at that time.
1955 CA, SC, WFE; 2 bottom SC plow, SC 6ft blade, no 7 sickle bar mower, 302 baler
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2014 at 3:47pm
Jim is right!  After WWII we received combines and roto balers made of aluminum.   We were glad to get them since the demand for machines was really high at that time.  I cannot recall a problem with them.
You could easily tell you had aluminum if you took your nail and pushed against the paint.  If it came off it was aluminum.
Good Luck!
Bill Long
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2014 at 4:53pm
Good Luck!
Bill Long
We have a roto baler that has an aluminum pick up apron.
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2014 at 5:21pm
The funny thing about the aluminum pickup balers is the first balers in 47 were actually galvanized pickups but the 48s went to aluminum. I have heard they were trying to cut down weight but went back to the galvanized a few years later.
Jim
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2014 at 9:01pm
I heard about the aluminum all crops during the second world war. I'm no expert but you would think aluminum for aircraft production would be more scarce than galvanized metal would be. Ryan
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2014 at 11:01pm
After the war, there was all kinds of aluminum available as surplus as the government canceled lots of airplane contracts.  Car makers didn't want aluminum as they weren't set up to stamp AL.  Scrap was pretty cheap back then as there was so much surplus war material on the market.  At least that is what I've been told.
Allis Express participant
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2014 at 9:21am
we had a 60 in the fencerow that all sheet metal was aluminum and got the same story about leftover ww2 parts
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2014 at 9:39am
I had a 'C' that had one aluminum fender and one steel. A local collector here has it now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2014 at 9:51am
I have an almost all aluminum combine sitting here for sale with no takers.  Needs some TLC, but in overall pretty good condition.  Even the bin is aluminum with no auger in the bottom,  the floor of the bin slants toward the front to get all the grain out.  Only about a 15 bu. bin.
$500 buys it.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2014 at 6:02pm
There is a bin bagger combo that I think will be at Hutch this year. It has lots of aluminum
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansasrustbuzzard Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2014 at 9:15am
I will get some pictures of it when I get a chance, I don't think its restorable, the AL seemed to stress crack really bad. It would be kind of neat to polish an Alcrop out like a P-51 though. Tongue Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2014 at 12:15am
Yeah, and put an Aillison on it!
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2016 at 11:38pm
I was looking at a 1945 All-Crop once, hoping to find some Aluminum, but there was none in sight. Just rusty sheet metal.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2016 at 12:24am
We have a aluminum 60 sitting in the yard
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2016 at 7:33am
If they weren't so flimsy I'd wish mine was one. Less rust! Lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 10:35pm
That's interesting. Seems at the vary least would be a good show piece
combinechris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 1:53pm
Aluminum wd used on 60's and rotobaler mainly because of shortages of steel because of WWII. I have a 60 and a rotobaler with aluminum on them
35 combines and 15 forage harvesters. mostly allis combines and equipment.WTB 2 row cornhead for a 90
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 7:46pm
I have one that is almost all aluminum, even the bin, the back, top sides, almost everything but the concave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 8:00pm
Can you post pics? What's the serial number?
