WD engine code
roadrunner(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roadrunner(IN) Quote  Post ReplyReply Direct Link To This Post Topic: WD engine code
    Posted: 06 Mar 2010 at 4:53pm
The WD  I just bought has a PA at the end of the engine number. I know what G and K stand for but what is P ?   WD300836PA  Thanks, Terry
Francis/Northern MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Francis/Northern MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 5:16pm
High compression engine in WD is designated by the letters PA.  Designed to burn gasoline only.  KA is standard compression.
Francis
Bemidji, MN
Post Options Post Options   Thanks (0) Thanks(0)   Quote roadrunner(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 5:27pm
Thanks Francis, My manual said GA for gasoline but didn't mention PA. Thanks again, Terry
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 8:52pm
my WD also has PA at the end, a KA or "dual-fuel" engine would have the 45 degree exhaust manifold with the plate that can be switched out, mostly on the early WDs
