CA Power steering?
CAturbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAturbo Quote  Post ReplyReply Direct Link To This Post Topic: CA Power steering?
    Posted: 22 Feb 2010 at 3:14pm
Has anybody installed a power steering setup from a D series
on a CA? I want to put a D series power steering setup on my
1953 CA. How do it? What parts need to be changed?
Waht problems doing it? Thanks for any info!
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 5:18pm
I was at work today thinking the same thing. It would be nice to have power steering on the ca. With the weights, loader, and blade, this thing might be a little hard to turn.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 5:53pm
Char-Lynn would be a simple way to do it. I have a Char-Lynn on my D14 and it works real well.JP
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 6:07pm
A couple of years ago someone on here posted about how to put ps on his CA. He used car parts from a junkyard, if I remember right. A small pump from a car and the steering sector was inside the cowling under the gas tank. What he had looked good but a person really needed to know what he's doing to get it together.
Leon B MO
Brian Ahart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Ahart Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 6:18pm
There was a gentleman who used to post on the forum who designed a PS system for his CA.  He utilized the bosses that protrude from the front shroud to attach a front-mounted pump.  He put a Char-Lynn torque generator inline on the steering shaft.  I don't recall where he placed the reservoir.  It was a very well-engineered setup.
A-C Weight ID reference and other goodies at brianahart.net
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 10:14pm
A D series system would not work.  The whole front casting would be needed and will not bolt up.  Steering linkage is totally different too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAturbo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2010 at 8:49am
Thanks a lot for all the input!
I certainly appreciate it, even though
it won't work. : - ))
P.S. I am still learning - I just got this little fellow.
