Location of Parts #'s
Spuds1963 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spuds1963 Quote  Post ReplyReply Direct Link To This Post Topic: Location of Parts #'s
    Posted: 01 Feb 2014 at 9:06pm
I own a AC 917 Hydro garden tractor. I recently called a few parts houses to order some parts for this tractor. I was told I needed the engine part #.  I have looked all over this tractor and I cant find any #'s anywhere. Does anyone out there have any suggestions?
Thanks,
Spuds
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2014 at 11:00pm
The engine model numbers would be on a silver tag on top of the crankcase kind of below the air cleaner. It is common for the tags to get lost or the numbers to rub off. It could also be covered with grease. If you know the engine is original to the tractor, I can look it up based on the trator's mfr# (found on the silver ID tag on the frame tunnel)
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2014 at 7:33am
Link to SimpleTractors website:
900 Series Engine Specs.
Gary
http://www.simpletractors.com/models/900_series/engine_specs.htm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2014 at 10:06am
Looks like it would be a Kohler Model K17H
Link to KohlerEngines website:
Gary
http://www.kohlerengines.com/manuals/landing.htm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2014 at 1:26pm
There are two versions of the KT17 used on the 917H. He will need the complete spec# to get the proper parts. If he can post the tractor mfr# I have an engine information manual that lists the spec numbers for each model.
