1937 wc
mcsiti View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcsiti Quote  Post ReplyReply Direct Link To This Post Topic: 1937 wc
    Posted: 10 Feb 2010 at 1:51am
Hey ive got a 1937 wc thats been in our family since my grandpa's dad purchased it new. My uncle used to use it every winter for snow plowing, however he was killed in an accident in 05. I just recent got it restarted (hell of a time cranking it). Runs like a top but i have a lot of questions about it. my uncle installed a set of hydrolics for the plow, and the hydro pump for it. It also has a radio, and headlight and everything seemes to run off of a 12v car type battery. a small steel box bolted under the left hand side of the fuel tank has some wires from this 12v system hooked into it. Anyone have any idea what the heck this might be? Also i live in north central indiana and need to know where i can get new plugs, and wires for it locally without having to drive or send off for them. Thanks for anybodys time for reading this.
mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 2:08am
You can get plugs and wires most anywhere. If it has a magneto, get solid core wires and use non resistor plugs. I got my wires at Farm and Fleet. Any auto parts store should have AC45 plugs. Post a picture and show the metal box your talkin about. We all like seein pictures.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 7:16am
First, welcome to our site and congratulations on obtaining your Grandfather's WC.  Having this in the family PRICELESS!!!
You may want to check with SteveNJ at B&B.  He is the best on electrical advice on this site.
There are two classes of WC tractors - styled and unstyled (flat top)- In 1937 the WC was unstyled with a boxy look.  The next year they came out with the styled WC which was more rounded looking.
Sounds like your granfather did a lot of good jury rigging on the tractor.  It probably does not have a generator so he may have a charger to keep the battery charged.  That may be the reason for the box.
Yes, if you can send us pictures.
Good Luck!
Bill Long
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 7:27am
need to get some badly rusted bolts removed from  tractor. what is the mixture that uses  ATF in it?
Max(ia) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Max(ia) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 8:38am
My 37 has starter and  alternator.  The battery box is mounted in the same place as the styled,  LH Frame Rail, to the back.  Welcome to a great knowledge base.
RyanTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 8:55am
Mike, to me it sounds like the box you are describing is a voltage regulator.  Does the tractor have an alternator or a generator?  If it is a genny, it should have a box that looks like this:
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 9:32am
Welcome to the AC family mcsiti! You've come to the right place for any questions you may have. We would love to see pictures of the tractor as alot of us have WCs here. Good luck and have fun with her!
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 11:02am
Norm's toys in Bourbon, IN can help you with parts and info.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 7:48pm
   we can help bring US331soth out of mishawaka and you will go right past our place on
331 i bourbon   1 mi.south of us30  can not miss it 1 block south of railroad
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 7:49pm
  thanks for the plug JORDAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcsiti Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 8:46pm
yep ryan that looks just like it. what does it do?
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 8:56pm
That regulates the rate of charge to the battery. Now, can you tell everyone if you have a generator or an alternator? Generator will most likely be cylinder-shaped. Alternator will be an alternator from some sort of automobile retrofitted on there. Newer Chevy-style alternators only have one wire and do not require the voltage regulator. Older alternators will have wires that run to the box you are talking about. A generator will also. Steve at B&B can help you better than me, he does this for a living. I'm just killing time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcsiti Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 12:25am
its a genny i think. mounted on the left front side if you were sitting on the seat. It long and shaped just like a cylinder. i think it has three wires attatched to it but not positive. its dark right now but ill make sure tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcsiti Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 12:29am
another thing too im posting a pic i found of someone elses machine, but it looks exactly like mine, almost the same rustiness too...lol
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 1:46am
Plevna Implement is an agco dealer in Kokomo, IN 888-882-3374
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 6:57pm
Are you the guy that posted on craigslist for help? If so I am the one that replied and sent you to this site. Welcome! Napa will have most everything you need. TSC or rural king has a lot of the items also. If you ever need a hand with anything, send me a PM. I pass through Granger quite often.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 7:36pm
very nice to play with.  I start mine some days just to listen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcsiti Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 9:54pm
yep that was me on craigslist. thanks for the help
This page was generated in 0.207 seconds.
