wd 45 head torque
nborga87 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nborga87 Quote  Post ReplyReply Direct Link To This Post Topic: wd 45 head torque
    Posted: 18 May 2013 at 9:41pm
Should the head be torqued to a different spec on a wd 45 engine if the compression is higher? It 'll be 10.5:1. If so what do you guys recommend? Thanks, nick
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2013 at 8:08am
  I have been told NO! Keep the same torque as normal, just be precise, torque in three stages. I have one running a bit more than that, I havn't had any problems.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
