D15 tranny fix?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: D15 tranny fix?
    Posted: 17 Jan 2010 at 7:57pm
What is average cost to repair 2nd and 3rd gear in series II D15? Looking at one that jumps out and needs fixing. Thanks Tracy Martin
Dave(NEPA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(NEPA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2010 at 8:05pm
From what I hear pretty expensive, but most of it is labor tearing everything apart to get to it.  Somebody that knows a lot more than I should be along soon to tell you how to check the shift fork and modify the detent to make it engage deeper into the gear, I learn more from this forum than any I and T manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2010 at 8:26pm
Dave, I can do the repair. I was wondering on parts cost. Thanks Tracy Martin
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2010 at 9:24pm
Tracy,
I sent you a PM with some part numbers and costs.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2010 at 10:38pm
Rogers,Thanks. Tracy Martin
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2010 at 6:11am
Tracy, I can also get the parts through an aftermarket supplier. I see about it today.JP
coastga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coastga Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2020 at 11:11am
I started having the same problem last year with my D15 series II. What was the cost estimate? Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2020 at 1:01pm
I still haven't got to it. Other stuff got in front! Tracy
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2020 at 1:58pm
I did my D12 which uses the same parts for around $800. I had to replace a bearing also.
It really depends on what you need when you pull it apart. Shift forks wore out? Might as well do Reverse while you are in there. Figure $150 or so per gear and then if the main shaft or pinion or both sets you need to replace....
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2020 at 2:08pm
This is what you find. Rounded off Dog Gears
Charlie
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2020 at 8:47pm
Last average price on parts I had was around $1000.  You won't know for sure until you get in there.  The input shaft also needed replacing on my 190XT.  That was extra.  Gears, collars, and bearings at minimum.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 8:18am
I rebuilt one. Had to replace the casting and the pinion shaft had parts of the teeth missing. I can't wait to rebuild another. (not) After I got it done the reverse gear sounded like the trans was full of a box of rocks.
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 9:17pm
Doing a 14 now 2nd 3rd and 4th with collars and three bearings gaskets seals and a few parts for  power director and have $1500
Albert
PrairieAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PrairieAC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 10:38pm
I kinda have the same issue with my D15 series II. Shifts into third fine and will hold the gear, but sounds like a can of rocks rolling around when your driving in third.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 5:28am
That's the reverse idler gear interacting with 3rd gear
I have the same issue on my D10 Series 3. Mine is a early serial and AC decided to revise the idler is that series. Well it was known to make noises and AC put out a service bulletin to correct it (If the customer complained). Later serials had it fixed from the factory.
I decided to fix this when I was redoing my brakes. I figured the gear alignment was off so I added a bit of medal to the shift collar. Now it pops out of 3rd, so my assumption was not right! Got to take it apart again and undo what I did.
I think your gear "rack" Lash or what ever its called, affects this also.
Charlie
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 7:19am
Charlie,
Do you know at what serial number they changed at ?
Thanks,
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 8:47am
I have to check and see if my service manual tells me. I need to find it first :(
Charlie
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 9:05am
The doctor reworked my shifter to improve engagement, doesn't pop out of gear anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PrairieAC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 11:55am
Well that sounds like good news. Maybe a cheaper fix than I original thought. So I'm assuming they have a different style idler? Or is it like a shim or different shift fork? The story goes dad was trying to pull something out of the ground that was buried. Took a little run at it and heard a noise in the tranny. Now third has always been noisey. The tractor is an early 1965. Sorry, not trying to hijack the thread. Just got me curious.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 6:23am
There are shims of various thickness to use as needed. But You have to tear it all apart to do that and then figure out which ones to use for the correct amount of slack.
Charlie
