WD 12 volt conversion
MN_M2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MN_M2 Quote  Post ReplyReply Direct Link To This Post Topic: WD 12 volt conversion
    Posted: 26 Nov 2012 at 8:54pm
If I wanted to do a 12 volt conversion on a WD and just change the ignition coil to a 12 volt coil do I use a resistor coil or non resistor coil?  Thanks
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2012 at 9:25pm
You can use either, but with 12volt coils so readily available why? unless you want it to look original, but then you wouldn't be doing the conversion.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2012 at 9:27pm
I suppose I should further explain what I was saying....
Do you have an external ballast resistor now?  If not, you will want an internal resistor coil, if you do, then you will want to remove it or buy an external resistor coil.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2012 at 10:36pm
My question is, why change?  Six volts works well when you keep things clean, and use thr proper cables for six volts.  Which are OO for power, and the strap for ground.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2012 at 11:27pm
I changed mine over to 12 volts, and put a delco alternator on. Used the old wireing harness and the old cables  now I have four halogen lights forward and one rear, and I can hook up to 12 volt controls and not be hinderd by the old 6 volt system. Was a win win for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2012 at 6:13am
If you use one of the 'newer' CS-130 series alternators, they are a smaller diameter, fitting and looking 'better'.As well tons of power available if you add an electric winch or two !
Going 12 volts also allows you to jump start the neighbour's 'greenthing' when asked !!
hth
jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2012 at 6:27am
We offer a complete 12V conversion either with Alternator or if your using a Generator. Drop us a line if interested. The kit gives you everything needed to do a nice neat pro wiring job. All you need to have is the ambition. Step by step instructions walk you right though the system back to front. We also offer a nice replacement 6V system. Optional Battery cables or whatever you need electrical....
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2012 at 7:09am
Why would any one NOT want to go 12V?  MACK
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2012 at 7:10am
Steve will set you up with a first class set up !! most of the tractors I have owned I have switched to 12 volt useing a delco look alike alternator, the way I look at it is if the next owner wants to go back original they can do it with minor work and in the mean time I have a modern system that will  "crank em up"  One thing that bugs me is when people install an alternator useing the gen bracket and take a sawzall an cut the rounded trim piece of the grill off instead of makeing a taller bracket -- That changes the originall return option  IMO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2012 at 6:38am
If they use our frame rail Alternator bracket kit, they won't have to do dat'. Its just a matter of adjusting the CNC machined support towers to raise the Alt above the shround. Actually, you can put the Alternator in service without the fan on it. Its not like the Alternator has a whole lot of work to do on a Tractor where it would overheat, but with our bracket kit, it isn't necessary to do so...
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2012 at 7:34am
If you are restoring to FACTORY orginal.........
1968 D15D,1962 D19D
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2012 at 9:19am
Put a 12 volt genie and saddle regulator on, I think that's what Im gonna do...looks original, Trev.
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2012 at 9:42am
I used a universal 12 volt coil I bought Farm and Fleet. No resistor. Has been running great for years. Some people say a resistor is necessary, but I have been running without and no problems.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2012 at 10:16am
There are 12 volt coils and 12 volt coils. Some require an external resistor and should be labeled as such. Some don't need a resistor and probably are only labeled 12 volts. Running a coil that needs a resistor without one will fry it eventually, giving the characteristic of running 10 or 15 minutes then quitting and not starting until about that much delay to let the coil cool down again.
Gerald J.
Jgear2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgear2001 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 12:32pm
Steve where do order one of these conversion kits?
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 12:47pm
Go to the top of this page and select the "Parts" tab. From the list of vendors select B&B Custom Circuits.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
albatros_3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote albatros_3 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 1:22pm
I have one of the alternator brackets from Steve and I like it a lot. The amount of adjustability is far more than I expected.
Krazy Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Krazy Karl Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2016 at 6:05pm
How much does your conversion kit cost
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2016 at 11:29pm
The complete kit for WD/WD45 with Alternator runs $475.+ shipping. If you take a visit to our website and look under "12 Volt Systems" you can see what the kit looks like, and what it comes with. We also offer our optional frame rail Alternator bracket it for those who do not want to be bothered with trying to fab a bracket. I designed it and it pretty much covers all the geometry needed to sit the Alternator in the right spot...
Steve@B&B
bb-customcircuits.com
