#52 or 53 SC plow on a D series tractor
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Topic: #52 or 53 SC plow on a D series tractor
    Posted: 05 Oct 2012 at 9:50am
John Sealey's post from a few days ago reminded me that I had seen a Service Bulletin on using the older 50 series plows on D series tractors.  He asked me to dig it up for him, and I thought others might be interested in seeing it as well.  Bear in mind that although the bulletin only mentions the D14, there were no other D series tractors in April of 1957, so this may apply to other models as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2012 at 1:51pm
Much like the SC blade designed for the WD/WD-45.
I have one blade where someone actually notched out a small amount with a torch, so the tongue would not hit the drawbar hanger bolt heads on a D15II.
The hangers can simply be unbolted but I run one of my other SC blades on the 15II, just don't slam it up against the hanger brackets, where the implement contacts the bolt head.
Will it still clear without contacting the body of the rear end after removing the hanger brackets?
Not sure, but I will check to see now as this has me to thinking.
Thanks for the info.
John Sealey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Sealey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2012 at 9:55am
Thanks Brett.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2012 at 9:26pm
I had converted a 53 pin hitch plow to snap couple for the CA. I had the hitch as short as I could go with it. When I hooked it to the D14 the hitch was hitting the PTO shaft.
I removed the snap ring and set it out the the last bolt holes, and it cleared fine. A longer lift arm would have worked also. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
