Dynoed my WC Video
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: Dynoed my WC Video
    Posted: 03 Sep 2012 at 7:16am
Ran my 36 WC on the dyno at Old Threshers yesterday.  According to the guy running the dyno she made 32 horse.  Has 175 pistons on a 4" crank.  Stock carb.  I wanted to run my WD again to compare them on the same day/dyno but I forgot to bring my drawbar in.
AaronSEIA
[TUBE]http://youtu.be/ds01y3s8nCM[/TUBE]
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2012 at 3:30pm
Thats pretty good!  My series IV 17 did 50 horses.  Some guy said that the live hyd pump takes ten extra horses away from the motor.  Any truth to that?
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2012 at 3:43pm
175 pistons are designed for 4.5" stroke crankshaft. You would probably be better off with WC/WD pistons.
Change to a wd45 crank and see what it does then!
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2012 at 3:52pm
Nice! That's a sweet sounding old WC!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2012 at 4:18pm
Sounds great except that GRRRR GRRR at the very end of the videoCry
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2012 at 6:03pm
Yeah, I'm not happy about the find'em or grind'em clutch on the old girl.  It's set up right, but seems to have some drag.  As for the 175 pistons, that was a setup that Tom Obrian at Ellis imp in Coggon suggested for me.  Claimed more power than stock pistons, but less than on a 4.5" crank.  I'm not sure I'm man enough to roll her over with 175 pistons and a 45 crank.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2012 at 6:57pm
175 pistons actually give you a lower compression ratio than stock WC-WD pistons. I have the 4 1/8 bore kit in my 35 and I don't crank much on her. Course I got an E start set up too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2012 at 7:22pm
AGCO OEM 4 inch bore model 175 pistons will pretty much equal WC/WD gas pistons in compression ratio and give you the Power Crater bowl for a little different sound. The fact that it has 32 HP instead of 28 HP would sure indicate that compression is just fine with a 4 inch stroke crank.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2012 at 7:30pm
I don't know that for a fact, but it sure makes sense
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2012 at 7:37pm
Thanks for the info, Dr Allis.  I knew Tom wouldn't steer me too wrong, he bled orange 15 years ago when I put her together.  it is an AGCO kit, so they are 4" 175 Power Crater pistons.  Always wanted to put it on a dyno and see what it'd do.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2012 at 7:37pm
Not 10 HP but 4 to 5 HP for sure....not 10.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2012 at 8:47pm
So if you get the same CR with 226 pistons in a 201, how is you can get higher compression putting 201 pistons in a 226? Are you talking all fuel compression or gas engine compression?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2012 at 9:05pm
When you install factory 175 pistons (that are 8.25 to 1 ratio with a 4 1/2" stroke and are 180 psi compression pressure) with a 4 inch stroke crankshaft, you are lowering that piston down to approx 5.75 to 1 ratio (gasoline) and 110 pounds pressure. Always remember valve protrusion and head gasket thickness have some affect on actual compression pressures.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 6:08am
I agree 100% with DrAllis. I put 175 pistons in my WD using the stock 201 crankshaft. Never dynoed it but the compression ratio is around the 110 psi. The 175 pstion is about a 1/4" taller than the WD piston but with a cup that has just a bit over 1/4 depth to it. It works out to be about the same amount of material above the wrist pin and so about the same compression is achieved with the benefit of a power crater piston, if there is much benefit.
Going a little off topic, some hot rod mopar magazine I read many years ago claimed an engine designed for a cupped piston gave better performance over an engine designed for a domed piston with all else being the same. The cupped piston would hold the exploding gasses better vs the domed piston letting more of the exploding gasses past the rings. Makes sense to me and I think the same would apply to a cupped piston vs a flat piston to a lesser degree.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 6:25am
Not to be nitpicky, but atmospheric pressure is 14.7 PSI, so if you have 5.75 compression ratio, the most you can get (theoretically) is 85 PSI.  Usually there are some losses even then, so would be even less.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 6:48am
A-C repair manual spec is 110 psi for a WD with 5.75 to 1 compression pistons.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 8:58pm
so...which combination of WD/WD45/175/D17components gives you the highest compression and/or horsepower? When I rebuild the WD I would like to add some power, thinking WD flat tops with a 45 crank? what would the ratios be?
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 9:12pm
  You can't always believe what you read. I  asked three piston manufacturers the same thing the article sugested and they said no way of proving one piston design made power over the other . simple factor is compression ratio makes power acording to the three . compression starts with ring placement and seal .Arias J&E Ross were the three i asked. ps one of the old pwer tricks on the 440 mopar was to swap the domes from left side to right vise versa the extra comp. really woke the 440 up.  final answere the piston that squeezes the air  fuel mixture into the smallest area makes the most donkeys . some where in the archives on this forum the 175 piston on 4 inch crank was determined to have as dr allis said again the comp and lonn mentioning the mopar article and me stating that i had asked three piston manufactures yada yada .but now Aron knows the fruit of his labor.
Edited by mlpankey - 08 Sep 2012 at 9:35pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 11:22pm
Now you guys did it... brought him in with his 'ring placement' soapbox again...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 9:47am
Please explain in the simplest terms, how swapping things from left to right would make an engine run stronger.
Rod B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 9:54am
Wrist pin offset.
Maybe drill the camshaft full of holes to lighten it or get it timed right.   He forgot the rest.
Though he did say not to beleve everything you read. This applies to anything he posts
Congrats on a nice running WC btw.
Edited by Rod B - 09 Sep 2012 at 9:57am
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 2:34pm
Its a dome piston swap side to side get the piston pin offset. pin offset .090 from factory emgine will rattle cold but goes awat when warm. Racers say its worth. 2 in a quarter in a 13 second ride.
Edited by mlpankey - 09 Sep 2012 at 2:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 6:06pm
Like I say. Wrist pin offset.
Now for pankey's homework assignment. Find an original M&W piston for an Allis 201 or 226. M&W part AP46 or AP48 and measure the wrist pin offset.
The M&W co was on to something.
Edited by Rod B - 09 Sep 2012 at 6:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 6:23pm
M@w offset to be quiet to so tunning them 180 would make the the power to like it does on the mopar swaping sides no homework posted that before you came to forum.putting the piston so that the first compression ring is position the highest it can be in the bore makes compression and taking away pin offset does just that.forged pistons suppose to be noisy.  If you believe in quench and squish a flat top does just that with the most piston top area to not to mention flame propegation is not impeeded across the flat either. if you like flames out the exhaust run dish pistons the fuel thats unburned do ti the insufficiency of the dish will do just that for you.
Edited by mlpankey - 09 Sep 2012 at 6:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 6:41pm
obviously you have not measured them and know verry little about the subject. When you have some solid info come back to play
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 6:53pm
dished pistons are ineffecient when compared to  flat tops in combustion  the flame out the exhaust from the unburned trap fuel by the dish pistons  proves just that. m@w pistons in 4 1/8 overbore made 8 more hp on a wc according to their advertizement . thats verry little increase due to design of piston / pin location when you take the cubic inch increase away from the over bore. only two ways to make horsepower on a naturally aspirated engine. compression is one cubic inches is the second way.everything else is just to support those two things.
Edited by mlpankey - 09 Sep 2012 at 7:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 6:59pm
Carefull pank. What you may realize (if you learn enough) is that power comes from an efficient engine design. Part of that may be rod angle.
It's going to be a trick assignment for you. But when you do find a piston to measure and come back with some solid info please tell us what the compression height of both an AP46 and AP48 are. As well as the pin offset.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 7:06pm
short rods make more torque by achieving right angle sooner. long rods are for sustained 8000 rpms or more. all torque engines have low rod ratios  its a trade for the increase cubic inches . The  800 inch big blocks have a low rod ratio its the facts of life . if high rod ratio is a  power secret then the 201 should of made more hp than the 226 but it didnt did it.
Edited by mlpankey - 09 Sep 2012 at 7:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 7:17pm
The point I'm makeing is so far over pankey's head he fails to even realize it. Pointless to go any further with the subject.
I didn't see you competeing in Eagleville pankey. Why not? Is it because you are your own mechanic and have nothing to compete with?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 7:22pm
we havent been to eagleville in a while .  how did you do . its not hard for me to txt tracy reed or call cody so no need to exagerate acomplishments.
