D14 PTO QUESTION/PROBLEM
allis d14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis d14 Quote  Post ReplyReply Direct Link To This Post Topic: D14 PTO QUESTION/PROBLEM
    Posted: 01 Sep 2012 at 5:22pm
LAST YEAR MY PTO GOT STUCK WHILE ROTOTILLING AND WHEN I WENT TO DISENGAGE THE PTO THE ROLL PIN SNAPED. TODAY I FINALLY GOT SOME TIME TO TAKE A LOOK AT IT. I GOT THE ROLL PIN OUT AND REPLACED IT WITH A BOLT. BUT THE PROBLEM I AM HAVING IS THE COLLAR WONT SLIDE IT IS STUCK ON THE FRONT SHAFT. HAS ANYBODY RUN INTO THIS BEFORE AND IS THERE A TRICK TO GET THE COLLAR TO MOVE. THE SPLINS LOOK OK I LOOKED WITH AN INSPECTION MIRROR BUT AS YOU CAN SEE SOMETHING HAPPENED TO THE COLLOR OR SHAFT MAKING IT NOT TO BE ABLE TO SLIDE. I AM DOOING ALL THIS WORK THROUGH THE INSPECTION HOLE. SNY HELP IS GREATLY APPRICIATED
CHRIS
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2012 at 5:38pm
I had same problem  when bush hoging . You have twisted the splines on the short  shaft . You can remove it with out taking tractor apart. I took a 41/2 side grinder and got mine freed up .  you need a slip clutch because you might not be as lucky next time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis d14 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2012 at 6:26pm
so did you cut the collar off and get a new one. did you have to file the splines
chris
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2012 at 8:00pm
I got the collar loose and strightened splines with grinder . There is  a notch  you can use to get big snap ring out  but to get it back i got a pipe coupling  and made an adapter  to drive it back in from rear where pto shaft comes out . You have to take freeze plug out of front but you can get one at a automotive store. The shaft has to come out . You  will know you have been there when you get it repaired! GOOD LUCK!
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis d14 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2012 at 8:50pm
does the front shaft come out pretty easy. i was looking at a parts breakown do i have to worry about loosing any parts up front behind the freeze plug when i pull the shaft out.like the spacer or bearing. is it a pain to get the shift fork back in with the detent ball?
thanks for all your help
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2012 at 8:11am
Ben a while since i done mine .I think when you take out big snap ring you can nock it out from freeze plug end. For some reason i drove the shaft back that clutch pedel works on to make it easier to get detent ball in. Happened twicee on mine and i put slip clutch on and haven,t had any more troble.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis d14 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2012 at 7:32pm
going to try a little heat tomorrow. looked at the splines with a mirror and all looks good. maybe if i heat it up alitttle it will relax the collar and it may move. if not i have to pull the front shaft out or split the tractor. i keep everybody posted
