D17 Wide Front Ends? HELP! |
Post Reply ![]() |
dishtech43 ![]() Bronze Level ![]() ![]() Joined: 05 May 2010 Location: Illinois Points: 17 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Aug 2012 at 7:58pm |
I have a 58 D17 with narrow front end..I found a Series 4 front end. I was going to buy it.but got too looking at my other D17 series 4,and seen the Yoke comes from the wide front end,and bolts to the Motor adapter plate with 4 bolts...and the D17 58 model, dont have the 4 bolt holes..will the front end work on the series 1 (1958) from the series 4? can anybody tell me what I need to find? thanks in advance..
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21832 |
Will NOT work as it is.....you'll have to fabricate something at the rear, and on those old D17's they only used 2 bolts instead of four.
That is what I thought..the only other thing would be change the motor adapter plate between the motor and transmission..that would give me the 4 bolts...well ,looks like too much work..Thank anyway...
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8612 |
Cleanest way to go is buy the engine adapter hsg off a series 4 and replace yours.
So I can do that!....I was wondering if it would work..but the front end off the series 4 will bolt onto the series 1 ?? beside having to replace the motor adapter...? thanks
Post Reply ![]() |
