allis chalmers b carb questions |
Post Reply ![]() |
tan454man ![]() Bronze Level ![]() ![]() Joined: 03 Aug 2012 Location: kansas Points: 15 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Aug 2012 at 8:29pm |
The zenith carb on my 1945 allis chalmers b I cant find info on it the serial num on carb is 218487 and then there a number under that its S1585 can sumone tell me what the letter means
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Just order a carb kit for an Allis B, C, CA, IB, and it will be the correct one. They only make 1 kit for those models. LOL Bob |
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
I did order a kit for it and and the only thing in the kit that worked was the bowl gasket and mounting gasket thats what im having problems trying to find a kit
I found info on all the other carbs that was used on an Allis Chalmers b just cant find any with that num on carb its weird its also different inside then the other carbs
You must have a replacement carb, not the original.
I had that problem with a D15 that I bought. I went all through the carb kit catalog at NAPA and couldn't find the kit. I bought the correct carb and everything is fine now.
Steiners have a kit for some of the replacement carbs, www.steinertractor.com, part # ABC1346. It fit several models. Bob
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6493 |
Contact Tony at Tony's Tractors (www.tonystractors.com). He located a kit for one of my B's that had an oddball carb on it.
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12007 |
An "S" 1585 is a "service" carburetor meaning its a replacement for one of the OEM carbs that was on it originally. Unfortunately, my book doesn't show that particular number, but I know for a replacement carburetor, you do need to order the correct rebuild kit for it....
Steve@B&B |
Thanks for the help guys I just got new carb and the tractor running like new
SteveC(NS) ![]() Orange Level ![]() Joined: 12 Oct 2009 Location: Nova Scotia Points: 663 |
Tan, Good news! but c'mon where d'ja get the carb? Is it brand new or rebuilt or just new to you? And, if you don't mind, how much did it cost ya?
Edited by SteveC(NS) - 06 Aug 2012 at 8:42am |
A guy I know had it it was completely rebuilt it cost 100 bucks
Good deal! seeing as your happy with the results.
Barnett3006 ![]() Bronze Level ![]() Joined: 19 Jan 2011 Location: Mid TN Points: 14 |
Hello,
If anyone has a 1949 B Zenith carb laying in pieces I need 2 dimensions taken off the main nozzle tube, if you would kindly take a second to measure it. Dimensions I need: 1: I need the over all length of the tube. 2: The distance from the top of the nozzle to the top of the fitting. Any other dimension I need I can get from whats left of the one I have. I didn't want to start a new B carb question thread. Thanks in advance, Marc |
Post Reply ![]() |
