ot brush hog
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Topic: ot brush hog
    Posted: 03 Jul 2012 at 8:15pm
i looking to buy a brush hog like 8 to 10 foot hyd. lift  what do you all use and how is it ?
                Shawn
190XT,D17and 7045
David G. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David G. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 8:40pm
I have a 7 ft Bush Hog brand. I really like it. They are a very tough machine. It has seen a lot of forearm sized tree trunks and still keeps cutting. Here is something to think about ...... I have a friend that is a Bush Hog regional sales rep and he still went out and bought a Land Pride cutter. He says the gear boxes are better and an overall better machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 8:44pm
really     thats good to kno i am willing to sell my red angus bull to get one lol  and thats bad cause i raised him from a calf.
190XT,D17and 7045
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 2:45am
I pull a 10' woods 121 with my 6060 and i love the job it does
there are bush hogs and then there are BUSH HOGS!
light weight, med weight, and heavy duty
what are you going to be cutting, this would be more important than size
if david G has been cutting arm size saplings with a 7' bush hog brand, he must have an 06 series bush hog.
these are monsters that run 100 hp box's and are the ones that made bush hog famous
they started life as a 206 model and are currently marketed as the 406, i have a 6' 306 and it has worn out several tractors
they still build the HD06 series in single box units and there is no comparison to the squealer line of bush hog brand rotary mowers
i also like   john deere mowers but again it is about what you intend to do with it
you put a light weight hog in heavy stuff it will not last long
blade tip speed will vary by manufacturer as well, faster is better
i personally would rather have a big 7' cutter with one box than a 8 footer with two
less parts to maintain
i also own a old trail type howse hd 10 footer but i can not recomend it in anything heavy
i picked it up used for $400, as a back up, that is the only reason i have it
Limestone rocks will kill any of them
i like old tractors of all colors
ranger42 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger42 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 9:04am
agree with ky wonder...we bought an old 6 ft. bush hog squealer used 15 years ago and that thing is bullet proof...it has had the heck beat out of it and it is still going strong.  on the other hand we bought a basically new 10ft bush hog 2510 model to lightly cut set aside acres and it has been nothing but trouble. We have gone through 3 gear box's. I'm looking at going to a fifteen ft. landpride myself.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 9:18am
I just went over 100 hours on my "new" 3pt mounted Bush Hog 3008.  I like it, it cuts much better than the JD MX8 it replaced, is about  a foot shorter so the front end of my 175D isn't in the air as much....and seems to pull easier.
I haven't used a Landpride 8' yet...but I have bought 3 of the six footers over the years and have had good luck with them.
 I like the twin spindle 8' over the single 7' because it is a lot shorter and doesn't scalp nearly as bad. It also mulches the grass more and spreads it out where a single spindle cutter has a tendency to windrow to one side.  I get comments all the time on how great a field looks when I'm done...even the next day LOL! I get a kick out of seeing these uneven scraggly looking fields that have been cut by a single spindle machine.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 6:02pm
i plan on using my 17 or xt to do the work  just to keep the grass down between corn and bean fields and along the woods  i have a batwing for the heavy work
190XT,D17and 7045
Russ SCPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ SCPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 7:30pm
Woods Brush BUll or an X06 series Bush Hog   If you really want to get serious look at a Schulte,  hold your pocketbook, but now that is a mower.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 7:57pm
Shawn,
how's your air conditioner working?
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2012 at 6:22am
Eldon, how do you keep the front end of that 175 on the ground with the 3008?  My 180 got light using mine so I added ballast at first then a 500 series loader to counterbalance the machine.
sks72107 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sks72107 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2012 at 6:56am
I think Eldon said he has a full set of suitcase weights out the front.  That is a fine looking setup Eldon has there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2012 at 7:39am
Originally posted by LouSWPA LouSWPA wrote:
Shawn,
 lou ya it works but i think it could be a lil colder but its ok     how are you doing
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2012 at 7:54am
Suitcase weights plus the front tires are loaded with calcium. I think the 18,4 x 30's throw a little more weight up front also.  I still have to back it onto my trailer. It is set up perfect for most jobs, turns on a dime, gets a little hairy mowing steep highway banks sometimes if I have to  lift the mower for an obstacle the mower wants to swing downhill and the front end uphill....good brakes are a must!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2012 at 10:01am
that is why i like trail mowers, everything i have is hilly, as far as looks yes the twin blades leave a better looking field, but i am cutting for weed controll and this old girl with the rear discharge shoot does agreat job, this is the old 306 seris bush hog
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2012 at 12:02pm
Ky Wonder thats the same one im using of my neighbors but its only 7 ft and it dont stick out past the 17   i want to stick with a pull type also .
                                  Shawn
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2012 at 12:32pm
I understand fully Eldon, they are great mowers.  I used ours to clear off a field(5 acres) of wild plums from 1-3" in diameter and at least 12 feet tall but in groves of 3-6" apart.  Used the PD as a hand clutch and eased up over clumps until the machine was done chewing then moved on, took a day but was worth it!  Mine has the mulching shields on it and man does it mulch!
My 180 has no weight in the front tires and I couldn't locate a suitcase weight set or the bracket to hang them so I opted to the loader.  I can pull on the trailer with/without the loader but it does get a bit light without! so I would drag the mower until I had the tractor crowning over.
