AC 6080
Western Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Western Maine Quote  Post ReplyReply Direct Link To This Post Topic: AC 6080
    Posted: 13 Jun 2012 at 5:56pm
 I have a 6080 that needs the drive shaft seals for the injector pump, they are a cup type seal. Can some one tell me where I could find them?
                         Thanks Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 6:11pm
Agco , or any injector pump shop should have them
Post Options Post Options   Thanks (0) Thanks(0)   Quote Western Maine Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 4:28pm
I got the seals now the tractor only runs a minute or two.
What I found was on the injector pump it's a Roosa master, If I loosen the 1/2" plug on the side it will run fine. I believe the return line may be plugged. Can any one give me some insight where to start ?
                     Thanks Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 5:28pm
Look ontop of the injectors and theres the return line , id remove it completely and blow air thru it then loosen the tank cap and blow thru the plastic line returning to the tank ; sounds like you may still have air in the system , if you loosen two injector lines and get full fuel thru them then tighten,the engine should run then you can bleed the other two , 6080,s are a booger to get all the air out
Post Options Post Options   Thanks (0) Thanks(0)   Quote Western Maine Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 6:12pm
I got it running. The tee fitting on top of the injection pump has a little be be in it and it was plugged, I got it cleaned out and away it went
                             Thanks for the help
                                       Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 11:07pm
It is time to remove the pump and have the weight retainer replaced. The rubber from the retainer pluged the check valve.   MACK
