d17 IV
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Topic: d17 IV
    Posted: 11 Jun 2012 at 4:02pm
What type of oil do i use in hyd system?
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2012 at 7:16pm
I use hytrans from the autoparts store near me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2012 at 9:50pm
I have always been told that most "universal" hydraulic fluids are much better than the stuff they had back when they were built.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 6:10am
Make sure the Universal Hyd Fluid is labelled compatible with "Allis Chalmers 821". There is also some new stuff showing up labelled "for older tractors". I have not checked the viscosity to see if it is a tad thicker but will be trying it in the D15II I use the most.
*My D-Series all tend to leak a little bit, but they are 50+ years old after all and at 100 F+ ambient, I am hoping to slow the leaks down until I get around to splitting em for new seals.
