220 fwa
camomax View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote camomax Quote  Post ReplyReply Direct Link To This Post Topic: 220 fwa
    Posted: 03 Jun 2012 at 8:53pm
What would a 220 with front wheel assist be worth if the serial number  is 1? Also if it was all original?
Truth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Truth Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 8:55pm
PICTURES!!!!
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 8:56pm
   Is this a hypothetical question ?
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 8:56pm
Model 220 serial numbers began at 1001 and the FWA models were years later, so it can't be "1".
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 9:10pm
   Serial Number 2223 would be the first 220 FWA. Is this the tractor your referring to, camomax ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 4:09am
Bout 50000 to the right person, , ill give ya 10000 ;;;
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 10:14am
There is a website, www.AC220tractorsthatdonotexist.com, that has all the info you need.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 10:20am
ROTFLMAO
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote camomax Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 9:17pm
Well I know a gentlman who has one that has had several mechanics from old allis dealers look for the serial number and the only one they could come up with was on the axle and it had a number 1. The location for the serial number was undisturbed so hasnt been ground off or what not. Any help on this would be greatly appreciated .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 10:00pm
Obviously they don't know where to look for the "chassis" serial number on the clutch bellhousing OR it's covered by some add-on cab mount.
Post Options Post Options   Thanks (0) Thanks(0)   Quote camomax Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 10:17pm
Its neither, i know that doesnt sound realistic but its never had a cab on it and there is no number on the housing. It doesnt make sense; I know, Im just trying to help him figure out whats what.
D21,200,6080,D17,D15,D14,
wd45, B, 720,
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 10:48pm
Could it be a proto-type or something? If it is, I'd guess the value of it to be out of this world. Does he have any history on it as to where it came from or anything? Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote camomax Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 11:21pm
 Thats what we are trying to figure out. It came out of wisconsin he bought it about 10 years ago from an older gentleman. If this would be a prototype I cant imagine the value of something like that. I just cant picture them not putting a serial number on the housing and only finding the "1" on the axle seems odd. By no means am i claiming its the first one built but it makes a guy wonder. Has anyone else had any of the same problem locating a serial number on one of these?
wd45, B, 720,
DaveCinIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 11:25pm
Bell housing replaced?
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 6:52am
Pictures are worth a thousand words.
1944 Allis C
1960 Allis D-17 LP
JarrodACFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 6:55am
My guess is that the "1" is a casting number. Maybe?
P.S. The only thing I would like better was if you said that you have a D21 FWA!
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 8:12am
Has it been repainted? sometimes people put the paint on so this the serial number gets blocked out.
"Better By Design"
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 9:39am
Casting may have been replaced. At the dealership I worked at, they told me of a 220 they had that had a leak when it was still new in warranty. It had a pinhole in the rear end casting that only had a layer of paint holding the oil in and by the time the new owner got it home it was leaking. They replaced the casting. They engraved the serial number on the new casting but I suppose not all shops took the time to do that.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote camomax Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 9:45am
It has the original paint kinda rough but the metal is pretty nice! everything appears to be original but i suppose it could be a replaced housing not sure.
wd45, B, 720,
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 10:32am
Yeah...the picture thing would go a long way here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 4:21pm
Picture?
"Better By Design"
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 6:40pm
Looked over my 210 and 220 and found no '1' cast into it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 6:43pm
Seeing that I am not an expert on the 220's, that was just my uneducated guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote camomax Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 9:42pm
Dont have a picture handy Im out of town for a few weeks as well I will post one asap. thanks guys for the help so far.
wd45, B, 720,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 10:21pm
I understand, just had my curiosity going so I took a look.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 10:30pm
Don't want to pass judgement but this story sounds similar to a Waukesha WC that was 'discovered' a few years ago.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 5:29am
As was stated earlier, if the 220 FWD is serial 2223, it is the first one. If it has no serial number, it is a 220 FWD with a replacement bell housing. As for the controversial Waukesha WC a few years ago, I do beleive it is real. I've done some business with the poster and he said his friend owns the WC. He did privatly tell me the serial number and the number makes it the earlist WC. I'm sure we will get more info in due time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 7:03am
Mr. Camomax, when you're there with your camera, please take a picture of the engine serial number tag. The serial number will read 3D-XXXXXXX. This would be an indicator of the chassis serial number when compared to other known "good" chassis serial numbers versus engine serial numbers. The engine number will never match the chassis (more engines built than tractors) on a 220, but will still give an idea where the tractor fits into the production history time frame. Years ago, I saw an old D21 series 1 that the chassis was like D21-1300 and the engine was 3D-01350....pretty close, but always more engines than tractors.
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 7:28am
Hey doc I have d21 1300  but that aint the serial # off of the engine at least not anymore
clint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 8:24am
wait wait wait- if the number "1" was stamped upside down- then it could make sense! ha- now that is from a couple years ago
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
