45diesel
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Topic: 45diesel
    Posted: 31 May 2012 at 11:55pm
WELL I FINNALY GOT AROUND TO STARTING THE WD 45 DIESEL I BOUGHT A COUPLE 3 WEEKS AGO. HAD TO PULL IT TO GET IT STARTED . IT WOULDN'T START WITH STARTER . PULLED IT ABOUT 100 FEET & IT STARTED TO FIRE , ANOTHER 50 & IT WAS RUNNING. IT HADN'T RUN FOR 7 YEARS. SEEMS TO ME IT HAS A MISS IN IT, BUT WHEN I GOT IT WARMED UP IT DIDN'T SEEM TO SMOKE ANY THOUGH. I DON'T KNOW MUCH ABOUT THESE DIESELS BUT IT RUNS & NO MOISTURE IN CRANKCASE SO THATS A PLUS. FOUND ONE CRACKED FITTING ON RETURN LINE LEAKING FUEL. PLAN TO DRAIN FUEL & PUT NEW FILTERS & SEE HOW SHE RUNS.IT'S BURNING CLEAN IN THE PIC.MAYBE SOMEBODY CAN TELL ME WHAT TO CHECK FOR THE MISS.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 7:14am
Great news!! I can see it at Hutchinson this july
Bob(FL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob(FL) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 7:56am
crack each injector line at the head while running till you find what cylinder is missing then find out why.
Richard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 8:22am
I had a 45 diesel once and it sounded like it had a miss.  Guy told me the exhaust from #6 cylinder had farther to travel than the exhaust from #1 which is true but that wasn't the problem.  When I would apply the brakes and make the engine work a little it sounded better.  Turns out the head gasket had started firing across between two cylinders so I replaced the head gasket and then it sounded good.  I was lead to believe the head gasket was a problem with the Buda engines but I never had any more trouble with it.
mark-east-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 1:54pm
Sounds like you might have a injector sticking , Ive had several 45'Ds and its a common problem with them if they sit for a while . You may have to pull injectors and get your local diesel shop to check them, most of time I just tear them down and take them apart and renew the nozzel and tip and set pressure with my nozzel rater and 99% of the time they run like new agian . If you need any help with it send me a PM .
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 9:58pm
the psb pumps on the 230 does not like the modern day diesel fuel.add a pint of marvel mystery oil to eacr tank of fuel...
