WD45 lift arms
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Topic: WD45 lift arms
    Posted: 10 May 2012 at 6:11am
my uncles 45 lift arms  will go up but wont come down unless you take a hose off  where do I look first ?
 Shawn
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 7:27am
There is a knob in front of pump that should be screwed out against housing. Screw it in and lift should go down. If it sticks up as soon as you try it again, pump needs removed and cleaned up. The control valves in pump need polished.   MACK
