Troubleshooting: Starting WD-45
redshed60 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redshed60 Quote  Post ReplyReply Direct Link To This Post Topic: Troubleshooting: Starting WD-45
    Posted: 29 Apr 2012 at 1:59pm
A WD-45 has been sitting with fuel in the system for a two years, up here in the Great Lakes Northwoods....I'm the (proud) new owner with no experience with tractors.  I drained the tank, took off and cleaned the sediment bowl, and took the carb apart -- soaked the components in Berryman's, and put her back together.  The gaskets look good and the float is in good shape and hinges nicely with no effort.  The needle valve and bolt cleaned and varnish-free.  Newly added fuel appears to be flowing freely in the bowl - bottom bolt, when taken out, fuel flows out.
The electrical system is 12 volt, upgraded perhaps 3 or 4 years ago.  New battery cranks the engine over, compression seems good, but no spark when I took wire attached to  plug out, and tried to jump the spark to the block while the engine was turned over.  The plugs look good - not too much soot, ash,  or electrode degradation.
Checked all distributor connections.  The cap and rotor look new!
Would appreciate any suggestions where to go from here.  Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2012 at 3:05pm
Do you have 12 volts to the coil when the key is turned on?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2012 at 3:09pm
As C Tucker says check voltage at the coil first. If this checks out the next step is the points and condenser.
Post Options Post Options   Thanks (0) Thanks(0)   Quote redshed60 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2012 at 4:46pm
Thanks, will check
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2012 at 9:47pm
File the points.  MACK
