Guess I screwed it up
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Guess I screwed it up
    Posted: 28 Apr 2012 at 1:02pm
Was doing a little grade work with a drag blade behind the 180D yesterday, could smell fuel then saw the dripping from the front seal area, pulled the dipstick and she was overfull by a lot.  I just replaced the injection pump a month ago, been fine til now, guess I did roll the seal and it finally gave up.  Oh well, time to change the oil anyway!
Edited by DMiller - 28 Apr 2012 at 1:02pm
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 1:34pm
Well you got a good engine flush out of it anyway.Wink
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 2:54pm
Well, you will have to fix the seal, but more than likely you didn't ruin the engine in any way.  Diesel fuel still has a lubrication factor to it.  We always used to run about a quart of diesel fuel or more as needed in our Perkins power units the night before an oil change.  For some reason a couple would carbon up real bad, and the oil would be too think to drain out, even on really short oil change intervals.
Still in use:
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 3:48pm
You apparently rolled the fuel side seal upon installation of injection pump. Bummer. Happens quite often. The important one is the tough one to get in too! Good luck, Ed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 4:51pm
I even had the little round pinchers to compress the seal and used STP on it, guess I will have to double check harder this turn, I did not use a mirror to verify last time.  I do have a packing hook(dull tip) this time so if it does try to roll I can nudge it around to flat.
Seems the hard lessons stick harder/longer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 7:51pm
There is a chance you didn't mess up, if the pilot tube spun out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 7:56pm
Man, I hope it has not and it is just a seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2012 at 2:17pm
Got to it today, I am getting faster at removing this pump, was the seal and I cut it when I installed it.  Now just waiting on replacement to show in the mail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2012 at 3:09pm
Sure hope you ordered two of them !! Not an insult,it's just nice to have a spare on the shelf..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2012 at 4:04pm
And yes BTW I did order two full sets as a just in case.
