Hundred series ROPS?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Hundred series ROPS?
    Posted: 27 Apr 2012 at 8:58pm
Anybody got pics of either style of Hundred Series ROPS on thier tractors? I would like to see pics of both. Thanks Tracy Martin
houchens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote houchens Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 10:26pm
I've got an original ROPS on one of my 185's and a canopy to go on it. (Canopy's being repaired and painted right now, and is not on for the time being). It's not the straight ROPS, it's slanted. I like the slanted the best, they look better on the 100 series. I will snap a couple pictures of it tomorrow and post them.
-ATW
8050 200 7010 185x2 D17-IV D15IIx2 D14 WD45 Deutz Allis 6260 Gleaner Kx2 Gleaner K2 Diesel 2300 discx2 600 and 333 planters 2 AC wagons several AC plows/chisels Rotobalerx2 Other Misc AC Equipment
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 10:41pm
I've got one from a 185 I parted out....doesn't have the canopy.
It is solid steel, goes thru a slot in the fenders and has a cross piece underneath that bolts to the transmission housing.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 10:58pm
Eldon, that is the one Dale brought down yesterday. It is some kind of heavy. I have the other type also.Both have the top cross bar but no canopy. Thanks Tracy
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 7:05am
Howdy Tracy,
Here is a pic with the AC 185 I used to have.
Kurzy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 9:46am
Joe did you ever have a tractor that didn't look great????
ALLIS EXPRESS!
This year:
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 10:10am
Tracy, here are a few shots of when I put ROPS on my 185.
I didnt cut holes in the fenders, instead I made spacers(length just a small amount than the thickness of the upright solid steel posts) and put the fenders on the outside of the
uprights.  You only lose the narrowest setting of the rear wheels.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 10:15am
Those spacers look neat, BUT THEY WILL KILL you if you ever need the ROPS. They have compromised the strength of the system. Solid plate spacers would be better than the bolt sleeve spacers, but neither has been tested by rolling the tractor over.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 10:26am
Gerald J.
Gerald the ROPS is mounted properly, he used spacers to mount the fenders....otherwise he would have had to cut slots in them.
ALLIS EXPRESS!
This year:
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 11:14am
As stated ZI believe the fenders are moundet to the spacers, not the rops
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 11:32am
The ROPS is mounted solidly and securly with new bolts per operators manual; proper grade, size, length, torque, before the fenders were installed.
The spacers are there to mount the fenders ONLY!  I made 4 per fender.  I saved an excellent pair of fenders by not cutting them!
BTW, all the information is in the owners manual, except the spacers.
Edited by JoeO(CMO) - 28 Apr 2012 at 11:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 12:02pm
Curious, whats the piece of PVC for?
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 1:21pm
Howdy Eldon,
Thank you, old friend said to me it only takes a dime to go first class. LOL
Kurzy
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 2:19pm
Heitman tractor salvage makes the new metal canopies for them that are just like the original. Reasonable priced too
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 3:01pm
Why so darned heavy steel?  The newer tractors use a tube steel frame for ROPS.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 3:56pm
It was built like everything else from that time. Heavy duty.
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 7:08pm
The other style is fabricated from formed steel, resembling tubing. I have one of those also. I need the canopy tops though. Thanks Tracy
This page was generated in 0.031 seconds.
