Wd45 valve cover torque specs
Allis-chalmers wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 valve cover torque specs
    Posted: 25 Apr 2012 at 9:06pm
Hey guys what are the torque Specs for the valve cover nuts ? I think there way over tightened thanks -justin
Edited by Allis-chalmers wd45 - 25 Apr 2012 at 10:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 10:01pm
Would his contribute to it smoking?
Rog(NCWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog(NCWI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 11:29am
I doubt it. Just snug them up. Use sealer on the gasket to stop any leakage. If it leaks, tighten up a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 11:35am
If it has been over-tightened, it probably needs hammered out. They bend quite easily and get distorted so the gasket doesn't seal properly. Take it off and use a straight edge to see how bent up it is. A nut drive will get the bolts tight enough without using a ratchet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 11:36am
Yes, if oil is leaking out from the gasket and running down on the manifold. It has nothing to do with burned oil coming out of the exhaust.
This page was generated in 0.048 seconds.
