7080 no power
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Topic: 7080 no power
    Posted: 25 Apr 2012 at 6:59am
just put the recently bought 7080 on the dyno yesterday for about 30 mins but only get 130 hp out of it. this tractor has been sitting for a few yrs but had a complete engine overhual couple hundrend hrs before parking it. just recently put an injector pump from a 7580 on it . it has the tank 3/4 full of 4yr old fuel. its starts and runs fine but just doesnt have the power i was wanting. this old fuel playing a big part in not getting the power out of it??? is the pump not turned out to the hp it should be??
sorry for the long post
thanks for your help
if farming was easy everybody would be doing it
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 7:03am
forgot to mention when the tractor is at full pin it really sounds great.. never been around a 426 with a turbo.. also the filters for fuel were changed and the filters for oil and the oil were changed aswell
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 7:09am
Are you getting any smoke? Could be that the turbo is not spooling up enough to produce proper boost.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 7:12am
Save yourself a lot of speculation and drain the tanks and replace with fresh fuel. Then, when you go back to the dyno have a 30 psi gauge installed on the intercooler and report back the reading under load.....should be 17 to 18 psi under load on a 70 degree F day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 7:13am
yes im getting lots of smoke. do you mean is it spinning fast enough to get the boost??? i dont know.. i do know that they had to reweld the elbow that comes right after the turbo because of a hole the size of your finger. could that be anything related to the problem?? not likely im sure.. on the way home from the dealer the elbow cam apart so i turned around and took it back.. no wating for a good used elbow.. whats a new one cost??
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 7:18am
i was thinking of doing that before i go any further . whats the easier way of drain the tanks?? i honestly havent looked at my new toy  close enough. but  dr allis thats the cheapest idea and i will do that first. many thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 7:19am
I would say 4 year old fuel would be part or all the problem. What about fuel filters? Make sure the shut off cable is pulling the lever all the way back and staying there.    MACK
Russ SCPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ SCPA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 7:19am
My guess with lots os smoke and low power, bad turbo,  also as simply as this might sound, check the torque on the bolts holding the "intake manifold", on my 7060 the bolts will back out a sniff and then allows some boost loss.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 7:20am
just thinking that the elbow wouldnt cause that much lost because its after the turbo not before
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 7:29am
Got a clean air filter?
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Bob wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob wi Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 1:00pm
I had 3 yr old fuel in the D-21 ( didn't use it much) it dropped 35 horse, new fuel, fuel filter's and it got it's 35 horse back and it did blow black smoke
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 1:27pm
Dont put 4 year old fuel through your tractor! Try fresh fuel and put some diesel treatment in, itll be alright.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 3:34pm
Check for any (bird, mouse, cat, bee, etc.)restrictions in the entire intake system. Too much restrictions can cause overfueling and black smoke.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 4:37pm
Besides turbo intake restrictions, check the pressure side-----make sure there are no leaks.
My SWAG is that the turbo bearings have rusted or crudded up from sitting for 4 years and the turbo isn't coming up to speed----------or the turbo is just plain worn.
Mark
GTH-L Simplicity
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 5:01pm
I would also double check that you have boost if any, if the dries out scaled carbon from the inside of the exhaust manifold all tried to come out at once, your turbo hot section is probably partially plugged and the compressor wheel isn't spinning.  I see this often on tractors that sit a while
Still in use:
