Value of V 16 Detroit and generator
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Topic: Value of V 16 Detroit and generator
    Posted: 25 Apr 2012 at 12:52am
I know it may not be the right area, but you could put in a tractor right?!?!?!
My friend and I were talking today and he has this 460 KW V 16 detroit diesel that ran a federal building in Portland area. Its in the NW now. Last ran in July of 2006 and has 980 documented hrs. Twin turbo and twin Superchargers. Weight of system with all the generator in tact is right at 12,000lbs.
So what is it worth, I heard that they have weak cranks? I was told a little over scrap value. I guess they really sucked fuel.
Anyways good or bad. I know the guy wants to get rid of it. I will find out cost tomorrow. If anyone is interested, you can PM me.
Thanks in advanced, Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
chevy436 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chevy436 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 5:32am
I saw a few of them with broken cranks. they are noisy but strong runners usually. there should be a market for that but more in the construction/mining area. that engine would be worth something if u could find a buyer. I have a 6v53 but have not tried to sell it yet. just my 2cents
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 6:08am
Darryl, thanks for the email pictures. The engine is a 16V71T likely about a 1976-7 vintage. The 8V71T was 350 HP in trucks. People either love or hate those old Detroits.
I have a soft spot for them. Too bad it's not a 12V71T because it would make an interesting install into an old Kenworth.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 9:47pm
71 searies had 71 cu in per cydl and  aprox 30 hp per cydl
T.J.-N.J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T.J.-N.J. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 6:48am
A company I worked for years ago had a very similar set up to power a portable concrete crushing mill. It had 2 275 gallon oil tanks for fuel and was good for about 2 1/2 days on fuel. The generator is worth good money in scrap and the engine is a good runner more of a curiosity piece now. I saw one in a long nose Pete 359 at a show. Detroit 2 strokes are good simple engines easy to work on and I like them but their day is past with $4.75 a gallon diesel. T.J.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 6:57am
Years ago (mid 70's) I ran a blacktop plant with one of those, it was in a van trailer with a undermount fuel tank that held about 2000 gal of fuel. That motor was two 8-71's bolted end to end somehow. As best I can remember it was 400 kva
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 11:42pm
The 2 strokes were neat in that you could change things around so much. Right or left hand rotation. Blower,either side. I saw 2 6-71's mounted side by side on some oil well equipment and the were mirror images of each other. Blowers were on the outsides and they drove a gearbox.One was LH and the other was RH rotation.
Edited by SteveM C/IL - 26 Apr 2012 at 11:44pm
