Help - Gleaner Combine
houchens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote houchens Quote  Post ReplyReply Direct Link To This Post Topic: Help - Gleaner Combine
    Posted: 16 Apr 2012 at 10:55pm
Have a Gleaner K, broke the end off of the power steering hose in the cylinder, and its flush with the cylinder. Can't get it out, I've tried an easy out, heating it, cutting it out with a chisel, and nothing seems to work.
What is the best way to repair? Would drilling it out and rethreading the hole work? Will I need a new cylinder? Need some fresh ideas.
Thanks.
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 12:15am
   If you didn't have any luck with the heat wrench, then personally I would go looking for a used cylinder.  If you had the last one available I would say keep trying to fix what you've got, but there are a ton of those combines in salvage.
MI8050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI8050 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 4:23am
Most likely the cylinder is the same as an E, E3, K2 and maybe the F's also.  Good luck!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 5:41am
I'd try drilling out just enough so that a thread chaser can clean the threads out. Should work easy cause you're already centered with a hole in the broken fitting. Flush the cylinder good afterward.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 6:34am
Weld a nut to it then screw it out.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote houchens Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 2:08pm
Thank y'all. Hoping to get it fixed soon.
albatros_3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote albatros_3 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 2:20pm
Take it to a machine shop. Any good shop should be able to get it out of there.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 7:10pm
Drive a new  allen key into the  fitting and turn the fitting out.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote houchens Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 9:51pm
Thanks guys! Managed to get it out this afternoon, thanks to some of yourall's suggestions, and fire the combine up. Getting ready to go through and change the oil, clean her up, and do a little fuel tank work, (the line is stopped up and we'd been using an auxiliary tank for the time being). Might need a tune up too, it's been awhile.
Thanks for the help, and dont go anywhere. May need some more soon. haha.
Bless you all.
ATW
This page was generated in 0.048 seconds.
