WC log skidder |
Post Reply ![]() |
orange blossom speci ![]() Bronze Level ![]() Joined: 15 Apr 2012 Location: ky Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Apr 2012 at 7:35pm |
Any body with info on a WC log skidder I spent 2days dragging this thing from a hauler in west west Virginia and brought it home to my collection here in Kentucky. Its drives are rearends from a WC power plant is WC serail no. stamped in chassis as Allis Chalmers forestry division. HELP!!!
Brian S(NY) ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: CherryValley,NY Points: 3380 |
would love to see pics. Brian S
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2237 |
Ditto! We're going to need pictures of it if possible.
Jeff B ![]() Bronze Level ![]() Joined: 17 Sep 2009 Location: Illinios Points: 43 |
I know of one in Iowa, don't know if it the same as your but All parts are wc. Frame is made from wc frame rails one on top the other and is articulated. I don't have any pictures of it but could get some in a week or two.
Jacob (WI,ND) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Kenmare, ND Points: 1248 |
sounds interesting, I'll be waiting for more pics and info on this as well....
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45 |
jnicol6600 ![]() Bronze Level ![]() Joined: 02 Jul 2011 Location: Sullivan Co. IN Points: 174 |
Pics please. I didnt know they exhisted.
Guys I'll get pics on here later this week, this thing was a hand full from Thursday til today, very rare item that I got, will go nice with the others I have.
scott ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: michigan Points: 2747 |
Sounds cool but wheres the photo?
Jim Lindemood ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: Dry Ridge, KY Points: 2569 |
That sounds like an unusual piece of equipment -- cool.
wade89 ![]() Silver Level ![]() Joined: 12 Feb 2018 Location: Northern MN Points: 221 |
Would be cool to see a picture of this. Currently trying to build something similar.
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6486 |
Need pictures! When I first read the post I pictured a log arch, also called a trip cart, in my mind then I reread it a saw it had an engine. Trip carts were used in this area in the 40's and 50's where they would put down a sawmill in a tract of timber and use them to skid logs to the mill. All I ever saw were locally fabricated and had an arched frame with two large truck wheels and tires in the rear and a Model A rear end set up as a pto driven winch which used a cable to lift a bundle of logs. For some reason most were pulled by M Farmalls probably because of the taller rear tires and the green ones wouldn't do the job.
Thats interesting. So the auto rearend drives some type of winch on the other side?
On this one there is a sprocket on the right side that drives a simple winch mechanism via a chain and on the left side is a ratchet mechanism that holds the winch drum until it is released (tripped) by a lever thus the name trip cart. Some have the brake assembly left in place on one side and it is applied to make the other side turn so then the pto can run all the time.
corbinstein ![]() Orange Level ![]() Joined: 31 Jul 2014 Location: Oklahoma Points: 796 |
I remember the winches on Pulp Wood trucks in Oklahoma in the 70's were auto Rear ends with a brake drum on one side, pinion driven by pto, and winch half way down the other side, with a home-made winch setup. worked fine as long as someone was holding the MC that kept pressure on the drum.
Post Reply ![]() |
