wd 201 in need of high compression pistons
Message Reverse Sort Order
wrightk20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrightk20 Quote  Post ReplyReply Direct Link To This Post Topic: wd 201 in need of high compression pistons
    Posted: 12 Apr 2012 at 10:06am
i just went and checked my crank and its part number is U3986. I do believe that if it starts with a U then it is the 4" stroke, but i could be wrong.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 9:56am
Nope, rods, head, manifold, everything can stay the same.  You'd be better off with a 45 carb and air cleaner to flow more for the cubes, but I've read here people say the WD carb can make the HP as well.  Are you sure you don't have a 45 crank already?  I've been in 3 or 4 WD blocks and they all had 45 cranks in them.  when I get home, I'll figure out the shipping.  Send me a PM with your zip to remind me.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrightk20 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 9:08am
I might have to take you up on that offer. It seems as though converting to a wd45 would be the easiest way to go. If i did that would i need a different head/manifold and carb?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 8:59am
I've got a couple of 45 cranks that need ground.  Would make you one heck of a deal on one just to not see it go to scrap.  Not sure what the grid would set you back though.
AaronSEIA
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 8:52am
Originally posted by wrightk20 wrightk20 wrote:
Or maybe is there a longer rod that i can run in the wd to get the higher compression i am looking for? Kevin
LOLGood grief, another 250 post mud slinging thread about to start,LOL
On a user tractor I would stay away from mods like that myself but who am I? LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrightk20 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 8:38am
yeah thats what i was afraid of. The pistons i took out were M&W ones but they are pretty well scuffed and have a heavy ridge in the cylinder. Is there anywhere that i can get a wd45 crank for less than $400? Or maybe is there a longer rod that i can run in the wd to get the higher compression i am looking for? Kevin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 8:14am
Pretty sure there are not any current production hi-compression pistons that will drop in. I lucked into a set of old stock M&Ws for our WD wake up. It is realy easier to go with a 45 crank. Several piston choices then including the standard WD piston which combined with a 45 crank gives a large comp ratio boost, I am thinking about 10-1?  This will require fuel beyoung 87 octane and timing adjustments but so will any other combination that yields a meaningful gain. We cant run regular with any kind of timing lead in our WD with the M&Ws and I think they are 8-1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrightk20 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 7:51am
hey guys i'm restoring a 1951 wd and i would like to rebuild the motor with some more compression and maybe a reground cam to get more power/efficiency. Does anyone know where to get any for the wd? i have heard that the 170 kit will give more compression in a wd45 but i was hoping that someone made a kit just for the wd. thanks, Kevin
