Built a weight stack for my WD45 |
KC-WD45
Joined: 11 Oct 2010 Location: Kansas City Points: 114 |
Topic: Built a weight stack for my WD45Posted: 30 Mar 2012 at 9:13am |
I work for a bridge construction company and got (5) 60lb bearing shimms from a bridge that we were doing some structural rehab on. I thought they would make a pretty good front weight stack for my WD45 that has a habbit of getting a little light in the front when plowing. I got them home and sand blasted the old paint off and sprayed them black then made a couple brackets out of 4" angle iron and 5/8" all thread. I think it turned out pretty good. How much weight do you guys put on your tractors?
KC-WD45
Posted: 30 Mar 2012 at 9:17am |
3/4" all thread I ment to say.
KGood
Joined: 17 Nov 2009 Location: Logansport,IN Points: 955 |
Posted: 30 Mar 2012 at 9:40am |
I have always seen 4 of the allis slab weights used(or more) and they are 70 to 75lbs. So thats about right. By the way it looks good and a little bit of grill protection to boot.
FloydKS
Joined: 12 Sep 2009 Location: S E Kansas Points: 8388 |
Posted: 30 Mar 2012 at 9:44am |
Looking good...when I saw the front on pic I thought you might be 'closing off' the grill from wind but the side view shows that your radiator will not suffer from lack of wind.
Nice add.
Skyhighballoon(MO)
Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Posted: 30 Mar 2012 at 9:53am |
Good job! You could use Allis 75 lb slab weights from the "Hundred" series to do that as well. I use four "Hundred" series weights on a home built bracket on my D17 Series IV except that they stack out horizontally not vertically. Mike
Edited by Skyhighballoon(MO) - 30 Mar 2012 at 10:01am |
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
KC-WD45
Posted: 30 Mar 2012 at 9:57am |
Thanks! I when I found those, with predrilled holes that all lined up and free to boot, I thought it must be my lucky day. I should have bought a power ball ticket!
Michael Crowe
Joined: 11 Sep 2009 Location: Kansas City Points: 1726 |
Posted: 30 Mar 2012 at 11:17am |
In one of the pictures it looks like the top bolt is missing a lockwasher and is not firm against the front plate. All three of those need to be tight or you will wind up breaking out a bolt hole.
David Maddux
Posted: 30 Mar 2012 at 11:48am |
Looks nice. If you come by any more of them, just kick them out at Holt, Mo. Dave.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 30 Mar 2012 at 12:51pm |
I had read somewhere that you shouldn't put the 'slab' weights on a W/F ? Yes or no?
