model 80 sicle mower pully removal
allister View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allister Quote  Post ReplyReply Direct Link To This Post Topic: model 80 sicle mower pully removal
    Posted: 29 Mar 2012 at 12:50pm
Has anyone out there removed the cast iron pulley=sheave that is on the twin wheel drive gear box ? there is no set screws or pins or clips, just a L shaped key as you can see in photo. I feel that I will need to heat up pulley hub and gently us a puller or drill and tap 2 puller holes unless someone knows a trick. Then I will have to heat pulley to re-install back onto shaft and hope I dont overheat oil seal. JL
1955 WD45    1959 D14   1963 D15II    1963 D17III all gas    OPOSSUM RUN OHIO
Bud(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bud(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 6:22pm
That "L-shaped key" is probably a tapered key.  It wedges in between the shaft and pulley.  If you can get it out the pulley should come off with reasonable effort.  If not, drill it out or be prepared to replace broken parts...
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 10:13pm
It is a tapered key. I had to remove mine a few years ago to replace the seal. I used a big chisel to get the key out. I then carefully heated and pulled the pulley off with a puller. Mine wasn't stuck that bad. Hope yours isn't either.
