off color question
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: off color question
    Posted: 24 Mar 2012 at 10:24pm
A city/country guy owns a red M that he leaves on our farm for his and our use. We cannot figure out where and how to add and or check the hydraulic fluid. Where do you add it and where or how do you check it??? thnaks for your help.
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 3:20am
On the right side of the tractor near the pulley there should be a fill cap on the top surface
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 10:35am
The old IH equipment had petcocks. Usually two,  one above the other. If the oil ran out the top one it was full. If it did not run out of the bottom one, you needed to add.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 10:44am
somewhere on the side of case is a level plug , take it out and pour oil into case till it comes out side plug.
