WC Rod Bearing Clearance
Bob in CO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob in CO Quote  Post ReplyReply Direct Link To This Post Topic: WC Rod Bearing Clearance
    Posted: 23 Mar 2012 at 4:15pm
I have a 37 WC. Does anyone know the rod bearing clearance for that engine. I think mine are a bit too tight. When I tighten the caps, the crank refused to turn.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 5:16pm
Sounds like you need shims at the ends of the caps.
Last I checked new engine clearance for Ford car engines was rated at .002 to .0025" with a wear limit of .005" checked with plastigage.
It may help after checking with plastigage to lubricate the bearings before cranking it over. A heavy oil is good, there is an engine assembly lubricant suggested for that. one engine I used a molybdenum disulfide grease from Dow Corning and that engine started well.
Gerald J.
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 5:55pm
The WC service manual agrees with what Gerald wrote. "The bearings should have .002 to .003 oil clearance when properly fitted."  Now that it is several years ago since I did my WC I can't remember how much shim material was needed on each side of the rod caps.
Edited by TomMN - 23 Mar 2012 at 5:56pm
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 6:15pm
Wondering if you could pull crank out, put cap's w/ bearing's installed, torque and read your ID on the holes. May shed some light on your problem. If it's in the budget, alot of rebuilders like to line bore those bores and rid themselves of the shims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob in CO Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 6:16pm
Thanks for the help. I may need to use some shim stock. Our parts house didn't have any shim material in stock. What kind of material is best to use?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 6:19pm
The few I have seen were brass shim stock. I imagine steel would be fine also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 6:41pm
Look for an envelope of brass shim stock at a hobby shop or hardware store that carries the K&S line of brass pieces.
One other thing to check, the bores are never centered in the caps, so reversing a cap is guaranteed to lock up the engine.
You probably need shims between where the cap and rod touch. I thought those were original in WC engines. Look in the bottom of your wash tank.
Any good car parts place should have plastigage for checking clearance. And might have shim stock. Shim both sides of the rod cap the same ammount. As a test cigarette paper is .003" thick but won't stand up to the engine running. Fastenal and McMaster-Carr I'm sure have all kinds of shim stock, but probably not in the local Fastenal store.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 6:44pm
On test I remember from VW aircooled engines was that a rod assembled to the crank without a piston but lubricated if moved to a horizontal position with the crank horizontal should move do the down position by just that weight.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 6:56pm
Small Parts is where I have purchased shim stock online.  The thin metal can be cut with a scissor.
http://www.smallparts.com/shims-shim-stock/s/16413251/ref=gw_c_m_s
Or you could hone them out to the proper diameter with no shims then you won't need them at all.  We did that on my RC:
http://home.comcast.net/~old_allis/ac-RC-engine5.html
Here is a video of the RC engine assembled with no rings to show there is no drag with all rod and main bearings torqued down and .002 oil clearance on each .
[TUBE]5tq7EbSh2kc&list=UUcuxd1GDOT3KuUMf5maX8ug&index=41&feature=plcp[/TUBE]
This was of course an extra step and I had to take them out and put the rings on and reassemble but it was fun to see that nothing was dragging.  I should add this was only done on the rods, I did use shims on the main bearings, they can be seen in the video.  I used plasti-guage to check everything.  The crankshaft should roll easily when it is fitted properly, this can be checked before any rods are put on.
Edited by TomMN - 23 Mar 2012 at 7:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 7:00pm
I think originally there was .010 shim on each side. The original shim is laminated and is in layers of .0025 so you can take one out of each side as the bearing wears. The biggest problem with these old engines is things get out of round. The best thing to do is bolt the cap to the rod with nothing in it, accurately measure the bore at least 3 ways, vertical and at about 45 degrees each way. If you can't shim it to a round bore that matches the OD of the bearing(minus your crush) get the rods fixed. I got a good set of rods and they worked great but my mains were out of round so I shimmed them to about .002 undersize vertically and honed them with a good Sunnen Hone to the original size. I ended up with .006 shim in the mains and after assembly I had .002 to .003 clearance with plasti-gauge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 8:28pm
Nothing like doing it Right the first time Tom.Smile
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 7:39am
Bob you talked about the rod bearings being tight- you also need to check the crank for out of round, as C Tucker said the right shims are laminated and can be pealed down to get the right thickness. also the shims DO NOT go between the bearing shells only between cap and base. the same with the mains. As said when right it should turn freely . remember they will run a little loose but will not run tight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob in CO Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 4:31pm
Thanks for all the great help. All was going well and then one of the bolts that hold the caps on stripped. It wasn't even to torque. Now I have to wait until I can get more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 4:42pm
Bob another yhing to look at is the castleated (sp) nuts, I was working on one one time and noticed the nut was cracked.
This page was generated in 0.030 seconds.
