No. 2 steel plow
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: No. 2 steel plow
    Posted: 28 Feb 2012 at 10:53am
I recently bought a No. 2 steel wheel plow, 2 bottom. (At least I think its a no. 2)
It has the spring release hitch, and I don't have the steel ring (Not sure what its called) to bolt to my drawbar. What can I use instead?
Galatians 5:22-24
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 10:59am
I used a twisted clevis until I found the original bolt on clevis. It worked but wasn't quite right!
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 11:40am
The twisted clevises as sold at TSC or Farm Fleet will NOT work correctly with the coupler. Things can bind and bad things result, I have a bent drawbar to prove it.  There are some older lighter built and longer twisted clevises that will work in a pinch but what you should have is a ring that bolts to the drawbar as Dipstick said.  Being as my stuff is all user grade and people are quite proud of the factory clevises I welded some up in the shop from 3/4 round stock formed to a "D" and welded to 1/2 x 3 flat bar with hole drilled for a bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 11:59am
Good idea Butch. Might have to make one up soon.
If anyone has an original for a reasonable price, I would be interested.
Galatians 5:22-24
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 12:20pm
Go to ebay and type in (oliver clevis). The oliver clevis has been welded. It would probly be ok but I would skip it. The short clevis would be the John Deere clevis which is much like the allis clevis. for all I know the short clevises are the same for both John Deere and Allis Chalmers.
A good Oliver clevis usually goes between 20 and 30 bucks. I have not paid attention to what the short clevis goes for.
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 3:41pm
AC part # LX-661   Call AGCO if you have time for some fun.  LoL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 4:30pm
Here are some pics tonight..
Complete, has this wrench on the side next to the frame, hard to see in picture. I was told that was original to the plow??
Galatians 5:22-24
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 4:31pm
   Don, I can sell one of the two plow clevises on the left (right one not for sale) if they will work. $30 plus shipping.
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 7:44pm
Yes Don it is a #2.  They were the only ones that had tail wheels that carried the rear of the plow when out of the ground. They were also available with a long  rear landside and no wheel  or a rolling landside(most of the time improprerly called a tail wheel) Those types had an adjustable chain over pivot on the hitch to pick the rear of the plow completely off the ground when raised and all #1 and #4 plows were made this way. In case you need parts for the bottoms those are #24
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 7:55pm
Randy, will have to think about it. Whats the green paint on the middle one? Oliver? Tell me it aint JD!!
Butch, thanks again. Think that wrench belongs to the plow? Its a double open ended wrench.
Also, I am missing 2 lugs on the drive wheel, if anyone has spares.
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:14pm
Shoot Don, I dont have any fancy fixens like prim and proper plow wrenches, LOL.
Can't say for sure about the wrench, one way to tell is every one of those I have ever been around that was prim and proper for the plow had openings that fit the nuts on the coulter bolts and the flat on the top of the shank. If more than two openings it should fit the nuts on the share draw bolt also.
Lugs are not an easy find, at least when I was wanting them. The head of the bolt wears down and then the lug can fall off the bolt and the bolt will rattle around until it will fall through the wheel.. If some are missng good chance the others are "there" too. Look closely at the lugs and you will see the parting line. I replace the bolts wth standard carrige bolts, 3/8" I think, been a while. They only look odd until you use the plow for half a day.
Edited by Butch(OH) - 28 Feb 2012 at 8:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:17pm
   Don, I don't think it is a John Deere clevis. These are Deere:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:24pm
LOL, I will have to try the wrench out tomorrow, and see what it fits!
Hope to try this thing out in the spring, will see what happens.
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:25pm
   Butch, this shows a #1 plow with a on-ground transport tail wheel:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:39pm
That does it! I aint playing expert no more!
My parts books dont show that plow. My mentor in such things Ted Buisker told me he had heard of 2 bottom #1s but never seen one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:46pm
Cool ad!
So I have a #1 then? or not? Mine has the fat axle hub so its a #2? I do know it has 2 steel wheels that I will not have to buy tires for! LOL
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:53pm
   Disregard that comment.
   Don, I agree with Butch yours is a #2.
Edited by Rfdeere - 28 Feb 2012 at 9:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:54pm
Yes Don it is a #2. There are other ways to tell the differant series apart but they are harder to put in to type written words. Used to be easier,, until Randy screwed things up, LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:57pm
LOLLOLLOL
10-4, will have to check it out better in the light tomorrow.
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:59pm
   Here is a #2 ad, I just noticed this shows one row of spokes just like the #1's, I guess that throws out the spoke theory :
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 7:44am
I have one like the one on the right. It can be bought.
Dusty
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 11:03am
The #1 is a lighter duty plow with a smaller tail wheel.
