D-15 Power Director
Storming Norman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Storming Norman Quote  Post ReplyReply Direct Link To This Post Topic: D-15 Power Director
    Posted: 22 Feb 2012 at 6:39pm
I had the PD rebuilt several years ago, but it never worked in low range.   Always jumped out of gear and made strange noises.
So it has been nice and I tired moving the shims, got it so it would stay either low or high range when you moved the pd handle.   But when you tired it out, it made strange sounds, and jumped out of both high and low range, and you could not hold it in place.
So what do I need to look for.   Kept the shims in either 1 and 3 and the long ones the center.
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 6:49pm
        I think there is some kind of lock that holds the power director in low or high range under where the handle is at. Never looked under there but there has to be something there that holds it in high or low. Someone will chime in that knows about this.
                                                           John Carlson
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 6:52pm
    Sorry about the last post. I was thinking about the 190 and this was a post on the D15.
                                 John Carlson
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 10:49pm
Long time since Ive seen ya Norm, how ya bin??    Sounds line the roller and ramps in the clutch backing plates are worn,  if worn they wont allow the clutch linkage to go over center and stay in.     As far as noises if the linkage moves to far it can contact some of the rotating parts and make a noise.     Id say your gonna have to take it out and  and look it over, something isnt right.  HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 10:51pm
By the way, make sure the lever is tight on the shaft, sometimes the setscrew holding the lever is loose, so it wont move the internal linkage far enough to go over center.    I dont know on yours but some tractors had a setscrew in the housing that held the  shifting for to the shaft, later tractors had two half moon keys and not a setscrew.   Good Luck
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 11:46pm
OK..someone enlighten me ... We have had this D-15 SERIES 2  FOR  probably near  50 years .. bought new .. never left the farm . replaced the clutch 3 times as it has a loader .. but the PD .. HAS NEVER BEEN touched .. 6000 hrs .. normal or ?
Engine  could use an O H  but havent got around to it yet ...
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Storming Norman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 7:29am
Thanks for the reply, Skip.   This tractor has the half moon keys.   Did check the bearings last night, seems like the front bearing on the transmission is loose, but will check out your suggestions.
Tractor has had a hard life, lots of neglect, but it coming back to life.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 4:45pm
BUMP
