AC 10 running gear parts
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Topic: AC 10 running gear parts
    Posted: 16 Feb 2012 at 11:45am
I have two AC 1010 10ton 8 bolt running gears that I am trying to find parts for them.  I am needing the following steering parts:
2 - radius rods (tie rod - 7/8"x57-58" pivots in middle)
4 - rod ends (tie rod ends 5.5" long cast with upright 1/2" threaded spindle hole)
6 - rod end - spindle plastic bushings
6 - stake (I call these bolsters where the rack is bolted or chained around)
I have tried AGCO, but no luck.  I have tried around others who are supposed to carry parts, but no luck.  Can anyone on here help me?  Thanks
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 1:46pm
Eric, the stake bolsters are pretty common.  i needed a couple for a running gear that the manufacture is out of business.  I contacted one of the current manufactures and he fit me with one of his models and I only had to drill one hole for it.  It actually fit the holes in mine, but i had to move it a bit to match the old ones.  CAUSE I'M CHEAP!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 1:48pm
PS.   Less than $15 each.
