Too good for a parts tractor
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Topic: Too good for a parts tractor
    Posted: 05 Feb 2012 at 7:36pm
I bought some tires and other parts and the rest of the tractor came with them.
It was traded at the local JD dealer. An average looking WD, havn't heard it run, it's supposed to have a bad battery but they pulled started it for someone else to look at. That person said it has a noise in the rear end and walked away. I bought it for $500. I want the wheel weights and the rear tires as well as the radiator and fenders. My WD45 needs tires and the other parts (the 45 was rolled last summer), the wheel weights are going on a D17. I've made a deal with archer45 that if he swaps the parts I'll give him the tractor and the bent parts and old tires so he will have his first tractor. Not the WD45 he wants but the price is right and at least it runs. LOL
It has a distibutor
It has a nice original exhaust manifold
The block was cracked and repaired, but it doesn't seem to leak.
It has a snap coupler hitch. The battery box is good, needs a lid but I've got one for him. The sheet metals not to bad either. If there is a noise in the transmission or rear end it probably has something to do with the missing shift boot. Seriously I think he can make it a usable tractor to mow his yard and possibly trade for a WD45 later on.
AGCO My Allis Gleaner Company
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 8:02pm
That precleaner is worth keeping if you work in any dirt.Oil cup almost never needs serviced.
MBwcenll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcenll Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 9:56pm
Yes, in fact I would be interested in the pre-cleaner to put on our  1t if you wish to sell it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcenll Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 9:57pm
Shoot I meant to type 15, not 1t.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 6:44am
Looks like you did pretty darn good there Dave! Nice Tractor
Steve@B&B
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 7:12am
Good deal!
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 8:11am
That is a Donaldson pre-cleaner.  I know you can still get replacement plastic bowls for them (at least you could 5 years ago).  Maybe even the whole assembly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 10:11am
I had a precleaner like that on my 45 before the rollover so that's another piece getting robbed. LOL
Does anyone know what these weights weigh? I have several F&H weights but these are thicker than the others
MBwcIll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcIll Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 10:28am
Two replys, yes new pre-cleaners are available and I am using one but-- the main part (base) is made of plastic and it has already broken.  My bowl is good, that is why I am looking for a medal one.  The second reply;  the F&H wheel weighs are the "starter" weights that go on spoke WC wheels. # 161 and # 162 make a pair for each wheel.  The F&H will fit just about every brand of wheel and the # 162 are the most popular to find.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 10:39am
I beleive the F&H 161's weigh right around 140lbs, and the 162's are right around 150lbs
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 10:45am
That is a good looking tractor! Rub a little boiled linseed oil on her & the paint will really shine.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 11:03am
I'll second that! It looks to be original paint!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 1:44pm
So Dave,whats the story on the 45 rollover.NF? Rammy driver? Any one injured? That's usually a reason for a funeral.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 1:53pm
It's a rare WD that doesn't have some some noise from the rear end/transmission in my experience. Mine has had the same sound for the last 12 years that I have owned it and it sees daily service. Has not got any worse!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 1:24am
Well we pulled it home, the trailer was tied up and it wasn't that far. The battery is junk so we'll borrow one from the WC later on and see what happens.
It howls a bit, we'll drain the fluids and see what comes out, I don't think it will be so loud when full of fresh oil.
The hood is pretty rusty to far gone tho polish, the rear rims are rusted through. It's all there but it'll need some elbow grease. The rear tires are a matched sey of 14.9x28 Firestones it looks like the rims are a bit to narrow. Aren't the 45 rims wider?
I doubt we do anything this weekend, we're going to the motorcycle show in Chicago Saturday. (The other hobby don't you know). Unless we mess with it Sunday afternoon.
 As far as my WD45, one of the boys ran over an auger derrick hidden in some tall grass. Was in third not going very fast and ran the right rear over a 15" tire. The tractor went over so fast he didn't even have time to push in the clutch. Thank goodnes he's young, he got clear. This is what it looked like after.
This page was generated in 0.158 seconds.
