sleeve puller ?
allis6080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Topic: sleeve puller ?
    Posted: 26 Jan 2012 at 1:23pm
need to pull some sleeves on a 301 and i dont have a sleeve puller. what are some idea's to get them out with out breaking them?
thanks allis6080
6060 s\n 5016
1947 JD B
Tim-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim-tn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 1:32pm
Is the engine still in the tractor or already out?
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 1:34pm
Before I had the correct puller I made one with threaded rod and a piece of flat iron that I stood on end and fitted to the jug . Weld the flat iron to the threaded rod standing on end then cut notches in the end of the flat iron to fit the bottom of the sleave and as wide as the block opening and you have just made a sleave puller. bigger threaded rod like one inch works the best.
sks72107 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sks72107 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 1:43pm
Ditto on what AC200Puller said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 1:46pm
tim. motor is out of tractor
ac200. thats along the lines of what i was thinking myself but thought some one mite have a better idea.
thanks allis6080
6060 s\n 5016
1947 JD B
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 2:22pm
4x4 works great if I remember correctly, it was the perfect size and a couple wacks on it and the sleeves popped right out, and this was a tractor that had coolant sealer put in it, so that helped hold them in...   I used that while it was in the tractor, but should be something you can do with the engine ou.
Hurst
1979 Allis Chalmers 7000
5800 Hours
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 5:49pm
I know this wont help now, but it might in the future.  I usually leave the engine on the tractor, and use a floor jack and a rod to push them up out of the block.
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 8:28pm
Here's how I got mine out... A piece of allthread, nuts, heavy square plates, a strong board.
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 10:22pm
The easiest thing to do is just knock them out with a block of wood. I did make a puller similar to the pics posted but it's just as easy to drive them out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 2:01pm
thanks guys for the info and pics i just made one up n got em pulled out. tried the hammer n block of wood but that didnt work very good.
thanks allis6080
6060 s\n 5016
1947 JD B
This page was generated in 0.048 seconds.
