? power steering fluid Char-Lynn
Michael Welch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Welch Quote  Post ReplyReply Direct Link To This Post Topic: ? power steering fluid Char-Lynn
    Posted: 25 Jan 2012 at 8:19pm
I have a WD45 with Char-Lynn power steering what kind of fluid do I need? Thanks Michael
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2012 at 8:22pm
i use dextron in the power steering on my WD45.
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2012 at 8:55pm
"back in the day" thay used ATF type F
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 7:45pm
Automotive ps fluid or Hydraulic fluid will work with the char lynn unit. The pump is the same as used on Ford and Chrysler cars in the 50's. You do not need the additives in the transmission fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Welch Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 8:26pm
I'm having trouble bleeding the air out.
Rich--MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich--MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 8:36pm
Do not know if my D 17IV has that brand of steering pump, but when I replaced the bearings and after filling it with fluid, I cranked up the engine and had the air problem.stopped the engine and cracked the output line, recranked the engine and with oil squirting/spurting after a bit it was retighten  the line to get rid of the air.
