govoner weight question
allis6080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Topic: govoner weight question
    Posted: 24 Jan 2012 at 5:51pm
what is the differance between the gov. weights in a lets say 226 combine motor VS. 226 tractor motor? do they make the gov. alittle more sensetive to work load?
now this past summer i put a 226 combine motor in my d17 and had a few people say to run the combine gov. weights. seems the tractor responds a little faster than it use. is this just my in my head or what?
 could some explain what the results would be between the two.
sorry if i seem to have rambled.
allis6080
6060 s\n 5016
1947 JD B
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 6:01pm
Dr allis can weigh in in this as well as I or anyone.the progression of the ramps and the weight as to how it acts centrifugally does make a difference.also makes a difference in the rpm it holds under load vs the max rpm it catches at
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 6:04pm
Dr allis can weigh in in this as well as I or anyone.the progression of the ramps and the weight as to how it acts centrifugally does make a difference.also makes a difference in the rpm it holds under load vs the max rpm it catches at.I personally haven't found d a weight that they can be slyslung g at above 3 grand where they wouldn't break and cause engine damage.
Edited by mlpankey - 24 Jan 2012 at 6:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 9:21pm
The weights are identical from WC -WD-WD45-D17. The models E and E3 Gleaner are different and the only difference is the fulcrum/ramp that moves the sleeve back and forth. The speed droop on the combine is 100 to 150 RPM and the other tractors are about 300 rpm. 170 and 175 are a different weight (lighter) and again a different fulcrum/ramp. They have 150 to 200 rpm droop. All three weights can be interchanged (in pairs) for different results in engine performance. "Droop" is how many rpm did the engine speed decrease from wide open no-load to full load (carb throttle plate is clear open).
EricSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 10:26pm
Very interesting makes me think about changing the weights in my wc that i pull
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2012 at 7:25am
thanks mlpankey and drallis. that creared it all up thanks again. allis6080
6060 s\n 5016
1947 JD B
Rod B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2012 at 8:10am
I lightened the combine weights and run a regular D17 spring. Made a 3000 rpm fast acting governor without needing excessive force on the weights. Put lots of hours on the tractor since then and pull it when I can.
Edited by Rod B - 25 Jan 2012 at 8:13am
