D17 piston and sleeve replacement?
paulinkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulinkansas Quote  Post ReplyReply Direct Link To This Post Topic: D17 piston and sleeve replacement?
    Posted: 30 Nov 2009 at 11:48am
This is a series III with a gas 226 engine.  It smokes alot, and uses about a quart of oil every 30 minutes.  I had the head rebuilt with new valves, guides and seals.  It still smokes.  Now I want to try replacing at least the piston rings or more likely replacing the pistons/sleeves with an overbore set.
My problem is getting the oil pan off.  There is part of the power steering system that appears to be blocking access to one of the pan bolts on the front right, and it looks like the steering shaft is going to block removal of the pan on the left.
Do I need to remove the front wheel and steering assembly in order to remove the pan?  It's a wide front.  I've tried hammering out the roll pin that holds a u-joint in place on the steering shafts, but it won't budge.
Can anyone give me some tips, procedure or advice on removing the oil pan?  I have the I&T manual for this.  It basically says to remove the oil pan to gain access to remove the pistons, but doesn't really explain what all needs to be done in order to remove the oil pan.
Thanks for your help.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 7:06pm
Remove engine from tractor.
kev/ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kev/ont Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 7:14pm
I would have to agree with chris on this, Removing the engine from the tractor will allow you to do alot better job of prepping the block for rebuilding. It sounds to me like you have a broken skirt or something of a similar nature for you to be going through a quart in a half hour.
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 8:03am
Pull the engine.  Pretty easy job on a D-17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 8:23am
Paul - it can be done.  I've done exactly what you are doing on both a Series III and a Series IV D17 for my dad.  Unfortunately, it was about 25 years ago so I don't remember the specifics on the problems you mention.  You might need a specialty wrench to get the tight fit bolts or something but yes it can be done without removing the engine or the steering shaft.  However, as everyone as said, taking the engine out isn't that bad a job on a D17.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 10:41am
If the valves and guides were wore out and the rings and pistons and possibly sleeves wore out, the crankshaft will more than likely need ground and new bearings. I would say pull the engine and do it all.
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 11:14am
You have made the top of the motor to strong for the bottom of the motor. To much compression for the rings and to hard on the bearings now. Replace them also and as said, make sure crankis right. They're usually not. Got mine turned and sized for $200.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 11:53am
The shop manual says the ft pedestal has to come off to get the pan off in the tractor. Like the others have said, better to just pull the engine and go through it. Hot tanking and shot blasting the block gets all of the crud and rust out of it. You'll never be sorry you did it 100%.
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 10:13pm
I just did an in-frame o/haul on my Series I.  I wish I would have pulled the engine, it would have been easier.
cheers,
Creek
roosky01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roosky01 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 10:55pm
Split tractor, removed and re-installed engine in a D17 twice in one day. Completely.....
Don't ask....LOL!
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Government always finds a need for whatever money it gets.
Ronald Reagan
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2009 at 12:26am
When you separate the front end from the side plates, the star shaped coupling will slide apart. No real need to remove the steering cross unless the joint is worn out and needs replacing.However, if youdo remove the role pin you'll need to strike it with a solid hit. Do this by placing a hard wooden block under the joint with enough clearance for the role pin. This wedge will keep the shaft and joint from "running away" from the blow. Get a good heavy hammer. That pin has been in there a long time and will need some coaxing to get started. The pin should have at least one side flush with the joint. Use the punch on this side so the blow doesn't flare out the head of the pin. If you don't have a flush side I;d grind one side flush if the first couple of blows doesn't move it. Once it starts it should come out pretty easy.
If your depending on the tractor for regular duty then splurge and remove it and give it the whole treatment. it'll then be good for another 25+ years under normal use. This may mean a combination of most of the above. Turn the crank if needed, maybe replacing the cam, a complete high compresion piston/sleeve kit, oil pump, carb kit, water pump and new hoses, plugs and wires and maybe an electronic ignition. Good time to check the clutch out, and fix any other leaks arount the tractor. Might even be time for a little paint.
WOW, look at that sharp looking and running tractor now!
