d 17 series 4 front seal
Doyle B(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doyle B(NY) Quote  Post ReplyReply Direct Link To This Post Topic: d 17 series 4 front seal
    Posted: 16 Jan 2012 at 9:34am
i have a d 17 series 4 diesel with the front oil seal leaking on the engine do i have to take the whole engine out to change it or and i just take the front end apart?
 thanks Brandon Doyle
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 9:52am
If your carefull and take your time you can remove the front bolster to acces the engine front end. Pull the crank pulley and pry out the oil seal with your prefered method. Watch out for a wear groove where the seal rides. You may need a wear sleeve.
Yea, I can fix that.....
