1973 Allis 7030 question
burtnick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote burtnick Quote  Post ReplyReply Direct Link To This Post Topic: 1973 Allis 7030 question
    Posted: 08 Jan 2012 at 8:18pm
1973 Allis Chalmers 7030
Any idea why the tractor won't move unless the differencials are locked in??
Thank you.
Edited by burtnick - 08 Jan 2012 at 8:18pm
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 8:23pm
Just a guess but a broken axle? What ever it is, it is at or after the differencial.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 9:14pm
 I'd get it where you can drain the oil out of the three drain plugs to the rearend and pay attention to how much shrapnel is on each drain plug. If either of the two outside plugs are full of iron, you may have a final drive that has failed ? which would be rare. If you have to lock the differential with the foot pedal to move, I'd just guess and say maybe all the ring gear bolts must be loose and sheared off?? quit using it NOW.....get it where you can drain the oil to the rearend and remove the left hand differential filter assembly completely and look inside......you'll see bolt heads on the rearend case floor??
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 5:22am
Spider gear pin came out.  MACK
