Music
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: Music
    Posted: 08 Jan 2012 at 12:14pm
to my ears when the B, I've been working on for a couple of years, fired up.  It is the 1st engine rebuild for me and was really thrilled when it fired up.  Had my grandson tow me on it about 50 ft. before it cranked.
While I'm typing,  at what distance is the seat frame mounted above the angle iron fender mounts?
Edit:  This is a hand brake model B,  I thought I remembered someone saying the seat height was different than a foot brake model.   Tim
Edited by TMiller/NC - 08 Jan 2012 at 12:28pm
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 2:25pm
That's great news Tim.  Will you have it at the show in May?
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 3:24pm
Myron,  I'm going to try, still have a lot as far as painting and getting a couple more parts, (rear tires, seat cushion, and so forth) rear rims need some attention.  Maybe just maybe it will make it...Tim
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 6:08pm
Tim,
I just bought a used seat frame from a B w/ hand brakes and it was bolted to the same bolts that hold the fenders to fender frames. Good luck,
Mike
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 6:37pm
That fealing you get when it fires realy wipes out all those other fealings you get when you are working on it that causes one to through things.
Congrats
The universal answer to all questions is yes, how much do you want to spend?
This page was generated in 0.045 seconds.
