Any tricks to remove a freeze plug? |
Post Reply ![]() |
Stan IL&TN ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Jan 2012 at 10:32am |
Have a one inch freeze plug on side of my engine block of my Ferguson that is seeping and I want to replace it. Any tricks to remove it? Just have fear that I will knock in into the water jacket to never be seen again.
1957 WD45 dad's first AC
1968 one-seventy 1956 F40 Ferguson |
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3911 |
Once you knock it into the water jacket just grab the lip with channel locks and pull it out. It won't go far the area inside the water jacket is not that big.
Gary in da UP ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
pierce with an ice pick, insert a screw then pull with a prybar, claw hammer , or whatever.
Thanks guys. Think I'll try the ice pick first.....................now where's the wife's ice pick..........sush now, don't spill the beans. She needs a new one anyway.
Jeff Z. NY ![]() Orange Level ![]() Joined: 11 Sep 2009 Points: 7326 |
Just knock it in like Dakota Dave posted.
It won't go anywhere. It will turn sideways and grab it with pliers and pull it out. |
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Everyone was correct and it's out! THANKS! I drilled a small hole and inserted a sheet metal screw and then grabbed it with vice grips. I was able to bow it out before the screw pulled out. Repeated with a larger screw and bowed it out more before it also pulled out. Then I took a screwdriver and hammer and pushed one side inwards which pushed out the other side. I grabbed it with plyers and out it came. A little nerve racking as there was plenty of room for it to drop to the bottom but it stayed in the hole and just spun sideways so I could grab it. Now to order a couple of 1 inch plugs. I know I'll just need one but my luck always seems to not be with me if I just get one. LOL
Any time I need to be certain a screw will hold in thin metal I punch the hole with a pick as it rolls the metal and gives a much better grip than a drilled hole. Anyway glad you accomplished the task. Take the rest of the day off.
Rick of HopeIN ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1296 |
on the B head they came out easy becuase they were rusted up bad. Poked an old srewdriver thru and they pried right out. Bad deal was I had just had the head redone at a machine shop and the guy did not replace them.
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 41341 |
Two types of plugs , one is cup type and other is the disc type are used in different engines . One just fills a straight hole and other has a machined stop in the casting .
Removal of each and instillation of each differ.
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful." |
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Make sure to use a good sealant on the new plug, like Permatex #1A
Still in use:
HD7 WC C CA WD 2-WD45 WD45LP WD45D D14 3-D17 D17LP 2-D19D D19LP 190XTD 190XTLP 720 D21 220 7020 7030 7040 7045 3-7060 Projects: 3-U UC 2-G 2-B 2-C CA 7-WC RC WDLP WF D14 D21 210 7045 N7 |
AC200Puller ![]() Orange Level ![]() ![]() Joined: 04 Dec 2011 Location: Wisconsin Points: 774 |
Post Reply ![]() |
