My new WD lpg
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Topic: My new WD lpg
    Posted: 09 Dec 2011 at 12:39pm
Here are some pictures of my new to me WD lpg.  It is setup to burn propane only, but I have the carburetor to put it back to the dual fuel setup.  I was hoping at least the tank was good, but it is rusted through and they used sheet metal screws to attach a gauge cluster.  But look what I found with the tractor.  How many people know what it is or have one?  Just curious to know?
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 12:57pm
Michael...I don't have a clue as to what the piece is for,but it looks like you found a pretty good WD LPG. Factory power steering,wide front end,straight sheet metal and good tires. Not bad,thanks for sharing!  Rick
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 12:59pm
   That is a WD-45 with WD block, there was no WD LPG / Dual Fuel. Or am I wrong ?
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 1:04pm
   That does look like a WD. Straight shifter, Plate on block. I am not finding any mention of a WD LPG in Swinford's book or Terry Dean's data book, What is this ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 1:05pm
Yes, there was a WD dual fuel lpg/gas tractor. If you look in the parts book it shows both a WD and WD45 version of the dual fuel.  The carburetor for the WD has a different part number than the carb for the WD45.  About the only difference I can tell is the coolant lines are different for the two models.  The above tractor is a WD, but the guy painted the 45 under the factory WD decal. The serial number is WD80093, straight shifter, old WD manifold, WD 2 port water jacket on top of the head, etc. Engine has a WD prefix, not a 45 prefix, so it is all WD.  The bracket that hangs down from the frame rails goes to a cultivator that I have but did not have the bracket, so that is an added bonus.  I will wait a bit before telling what the little bracket it.  I will give a hint though. It is a factory piece and it is in the parts book.
Edited by Michael Crowe - 09 Dec 2011 at 1:36pm
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 1:14pm
So that's why you were interested in any dual fuel parts I may have sitting around... :-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 1:34pm
Yes, that is part of the story.  I do have the carburetor for this one, but I have another WD dual fuel that I could use the parts for.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 1:48pm
Hydraulic lever stop for using the traction booster????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 1:49pm
   Why is there no mention in Wendel's, Swinford's, and Dean's books of LPG until the WD45 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 2:13pm
   The AGCO parts book online lists the LPG carb (page 114) and fuel system (page 138) on the W226 engine, I am finding no reference to the parts on the 201 ?
Edited by Rfdeere - 09 Dec 2011 at 2:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 2:28pm
Matt, you are correct.  I can't say why the history books don't show it, but the AC parts books do.  It lists a different carb for the WD than the WD45, and I have one of those carbs with the WD part number on it, as well as a carb for a 45 with the 45 part number on it.
Edited by Michael Crowe - 09 Dec 2011 at 2:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 2:53pm
   Okay, I see it on page 116. Still listed as 226 engine. Interesting Mike, wasn't meaning to give you a hard time, just wanted to see documentation. No hard feelings meant. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 3:06pm
   Oh, It is a neat and interesting tractor. I think that I have seen one of those hydraulic stops before but don't remember where.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 3:33pm
No offense taken.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 9:07pm
It is kind of funny, because of the WD and WD45 being so popular or should I say so plentiful, I never had a lot of interest in them, I always thought that when I was ready for one, I could buy one on any street corner. So I spent most of my time and interests in the knowledge of the more rare tractors. Michael is the exception to the rule, he studied and found all of the rare and interesting options of these tractors. Now he is my go-to guy for information on these. There is a lot more to know and to look for than I ever could have imagined. All AC equipment has quite a history if you spend enough time to learn everything there is to know about the item. Michael Crow is an Authority on the subject, among others on this Forum. My hat is off to you Sir. Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 9:37pm
I am making those stops now out of aluminum. Machined not cast, if you are interested let me know. I borrowed a part to copy from Tom in IL. Tracy Martin
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2011 at 8:19pm
My grandfather had a mix of 5 or 6 WDs and WD45s, all of which burned LPG. Only two were converted the rest were factory, I am fairly sure only two of his tractors are 45s.  So While I don't want to state as fact without looking at them, I am about 96.32% sure a couple of the WDs are factory LPG or Dual fuel
Still in use:
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 7:25am
I have some Ensign service information that a friend gave me this summer, and there were 5 different sizes of the Kgnl dual fuel carbs that they made, amoung many other styles. One thing they mention in there is the venturi sizing needs to be checked when putting the carb on another engine. In the parts section when ordering you must specify the venturi bore size. I would certainly think that the WD45 carb would have a bigger bore thus making it a different part number, although they are physically the same size. Interesting Carbs made from brass except the float bowl. Some real thought seems to have went into them.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 9:11am
Guys, this might clear the dual fuel thing up for you, I hope. LOL
I just reread this in sales flyer # TL-1122-5603 (I'll try to post a copy of this later on today)  it is talking about the WD45 / WD "Dual Fuel"
Here go's  [QUOTE]  Available in three popular front-end styles, the WD45 with L-P gas conversion weighs approximately 4640 pounds.
L-P gas conversion units are available for either factory or field installation on WD45 tractors, and for field installation on WD tractors.
I hope this helps.
Don
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 10:29am
Now that we are on the LP subject. What is this? Was at Hutch or Hastings in 06 and the owner claimed it was a very rare factory LP only that was dropped when the diesels came out because it had more power.  What is the story of the manifolds?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 10:37am
had to delete some pictures. View of the whole tractor. Same guy had  a D-17IV LP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 11:30am
That is a Leroi manifold, so probably a Leroi engine also. And not factory.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 11:31am
Don , I would love to have a copy of the brouchure. Calvin, I too saw that tractor in person and all I can say is that the parts book does not show anything like that ever being offered by AC. I have never seen any literature or parts that showed anything but ensign carbs and regulators.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 11:45am
The guy also showed me a well worn brochure with A-C logos to show the tractor as factory. Maybe someone was marketing a conversion kit with all these parts and had the A-C logos on the brochure. He obviously started with a new hood because there is no patch over the originial muffler locatiion. That does look like a good manifold.
Edited by Calvin Schmidt - 11 Dec 2011 at 11:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 12:08pm
   Well then, were WD's available or not with LP ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 12:15pm
I looked in my AC price list and it list two separate part numbers for the dual fuel setup, but it does have an asterisk by the WD and says it is a field conversion. So, with Don's literature, it would strongly suggest that WD's did not come from the factory as an LPG, but you could order the parts as a kit to have it done at your local dealership or I guess do it yourself.  The tractor I posted about has factory power steering as well which never came out on a WD from the factory, and every little bracket and clamp is there, so I suspect the dealer put that on as well, as a farmer I doubt would have been so careful to put all the clamps on in the correct places.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 12:19pm
Calvin, now that I recall, that tractor had a D17 motor in it as well.  There were way too many things that did not add up for me to believe that it was factory.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 12:21pm
   But, could you order the LP parts when the WD was being built ? Or after the WD45 Dual fuel came out, then they were offered to retrofit WD's ? Where's Sherlock Holmes when you need him ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 12:23pm
I have an original copy of the Form No. 528 "FIELD INSTALLATION OF POWER STEERING WD AND WD-45 TRACTORS" it shows gasoline and diesel. One could assume the same existed for the LPG setup also. At one time I thought I had the same Sales flyer that Don talks about stating the field installation of the LP on WD and WD-45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 12:36pm
Randy, I am just guessing here.  I had always assumed that a WD could be had new as an lpg dual fuel but only with the gas high altitude piston (6.6:1 ratio) offered for the WD, as they did not list the lpg piston until the 45 came out.  My assumption continued that field performance must have been lacking with the WD configuration, thus AC changed the 45 dual fuel to the higher yet lpg pistion (7.25:1ratio).  I gleaned all that from the parts book data on the various pistons, etc.  But like I said in my previous post, with the sales literature I have and the piece Don quoted from, it woudl suggest that the WD lpg setup came out only after the WD45 came out, and that AC made a separate kit with a different carb for the WD.  But then that would conflict wtih Orangeblood's belief that their WD's came with the dual fuel already on them.  So all I can be sure of at this point is that AC did make the conversion for WD's to have the dual fuel configuration, just not sure if they ever came from the factory that way or if it was a dealer conversion.
