Cracked inner wheels on D14
John Sealey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Sealey Quote  Post ReplyReply Direct Link To This Post Topic: Cracked inner wheels on D14
    Posted: 27 Nov 2011 at 2:56pm
Both of the rear inner wheels of my D14 have cracks going from the square holes to the inside mounting holes. There has been what looks like many attempts to weld them. They have just cracked again beside the welds. I suspect they have cracked because the 14.9" tires are loaded and quite heavy. All that weight spinning around must put a lot of strain on the stamped steel wheel. Can you still get new wheels? Or is there a good way to fix these rims?
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 3:21pm
There should be plenty of used centers around, I have a set but probably too far away from you.
ALLIS EXPRESS!
This year:
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 6:19pm
  i think we have a set of centers in stock   1-800-254-3116
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 6:34pm
Hay John, I'm near Hamilton and have 1 good center , if that's any help.
Jay
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 6:36pm
Fawcett's may have good used centers or know where to get some. I have a parts D-15 II that may yield a good pair of centers if you are not in a hurry. PM me
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 7:10pm
I have two near Windsor, where are you located?
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 9:26pm
I got one from Fawcetts a few years back as well.  Even had good original paint on it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Sealey Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 5:40am
Calvin Pm sent.Chuck I live in Lyons just north of Aylmer ON. Myron where is Fawcetts? Jay I will be going to Burlington for christmas I may have to drop by. Norm sounds like you have a lot of AC parts are you in the tractor wrecking buisness? Thanks Eldon but it looks like there is some close by just have to know where to look.
Steve(SEMN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve(SEMN) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 9:09am
Mine were cracked too, I was told that the model 82 side mower's vibration cracks them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 10:41am
John, I see you are quite a ways from Windsor. Fawcetts  is near St Marys, northeast of London.
1C 1 WD45 1 AC180
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 11:00am
I doubt it was caused by the weighted tires. There are LOTS of Allis's out there with fluid in the tires. I would suspect somebody didn't keep the eccentrics tight and the shifting caused excess strain on the wheel. ????????
This page was generated in 0.046 seconds.
